Old 02-24-2021, 03:38 PM   #1
Default How to Replace Fog Lamp 2018 M-B Sprinter
I need to replace the driver’s side fog lamp on my 2018 Winnebago ERA 170X (2017 M-B chassis). I looked at YouTube but didn’t really find help. Some have suggested the beauty ring around the front of the assembly “pops off”. Then remove three Torx screws to pull assembly forward. Others indicate it must be accessed from behind under the bumper. Any of you with first-hand knowledge that can shed some light on this?
theHueg is offline   Reply With Quote
Old 02-24-2021, 05:33 PM   #2
Not sure it would help, but it never hurts to post a picture. Are they Mercedes OEM or something added by Winnebago?
Old 02-24-2021, 06:12 PM   #3
M-B original.
File Type: jpg DAC1E391-A321-4751-A901-79952A3BF3C5.jpg (175.2 KB, 3 views)
Old 02-24-2021, 06:28 PM   #4
It seems that small hole has to be important on some way. Could be just to drain water/moisture, or it could be access to a screw or maybe just a pry point. But some Mercedes owner will probably know. Just need them to see your post.
Good luck.
Old 02-25-2021, 12:23 AM   #5
It is simply an adjustment screw to aim the fog lamp.
