Old 05-17-2022, 01:39 AM   #1
Default PowerStar LW3000W-12-C Inverter/Charger Repair
Hello all - long time listener, first time caller!
I have a 2015 RoadTrek Adventurous with a PowerStar LW3000W-12-C inverter/charger, four 6V 210 Ah AGM batteries (wired in series to create two 12V banks), 300W solar, and 2nd underhood alternator. I have noticed recently that while connected to shore power, the inverter/charger will not charge properly. It starts out with charge voltage of 14.4V just fine, then when it drops to float voltage of 13.8V, the internal fan usually kicks on and voltage slowly drops draining the battery over time (many hours). I have noticed that occasionally the fan will stop running, and the charger will bounce back up to 13.8V float. Then the fan will start again, and the voltage begins to slowly drop. I first noticed the problem because I heard the inverter fan not cycling (always on) and therefore draining the battery. The inverter fan operation does not seem to be dependent on ambient temperatures - it was running non-stop when it was very cool outside. In the course of determining the cause, I cleaned all of the 12V positive and negative connections and load tested the batteries (all good). The system charges fine from solar and 2nd alternator. Therefore, I conclude the problem is with the inverter/charger.
THE QUESTION: does anyone know if the charger part of the inverter/charger can be repaired? I am willing to pull it apart and give it a try before pursuing a replacement. Thanks!
Worsey is offline   Reply With Quote
Old 05-22-2022, 04:45 PM   #2
timp410's Avatar
Following, I have a 2016 with the same configurations.
timp410 is offline   Reply With Quote
Old 05-22-2022, 05:58 PM   #3
Luv2Go's Avatar
It's very hard to find someone who will try to fix these types of inverters, mainly because it's not cost effective. Here is a thread from the Sprinter Source forum which mentions the LW... part number, one poster mentioned repairing a loose wire.
Here is a manual for a 220V version of the inverter, it shows how to set battery type. Toggling between a couple of types may help if it forgot it's configuration (that can happen as non-volatile memory can fail). If you're going to pull it apart, here's a video of what you should expect (this is a 24V but a 12V should be the same):
As far as replacement, here is a link to a post on this forum regarding that, there seem to be plenty of options.
Stewart, Brenda and kids
Luv2Go is offline   Reply With Quote
Old 06-01-2022, 02:23 AM   #4
a quick follow up - the short answer for finding an easy repair to the inverter is NO. I talked to a professional and his response was, if i can get a replacement for a $1000, then that's the way to go. So I decided to pull the cover off, blow any dust out with compressed air (it was pretty clean for 7 years old), then re-evaluate. I also changed the battery setting from "Gel Euro" to "AGM 2" charger settings. I figured if there was something burned out in the Gel Euro setting, maybe the circuits for a different profile would be OK. As it turns out, the charger behaved better on AGM2 setting, but the voltage is still dropped when the cooling fan kicked on (approx. 0.5 volt below float). When the fan stopped, float voltage returned to normal. As a trial, I purchased a Genius Noco 10 charger and hardwired it into the +/- lugs on the back of the inverter/charger. I turned off the inverter, and used the Noco10 as my battery maintainer. It is doing a fine, consistent job maintaining 13.3 volts in float. I never really liked leaving the expensive inverter/charger on non-stop while in storage (sure seems like you're asking for an expensive component to burn out), so I think I will pursue this work-around for the season, then re-evaluate. If the inverter/charger does an adequate job this season (that is, not drain my battery when on shore power), then I will keep it and use the Noco10 as my primary maintainer when the van is stored at home.
Old 08-02-2022, 06:59 PM   #5
Following, I have a 2017 with the same configurations.
StuartW is offline   Reply With Quote
Old 08-05-2022, 12:26 AM   #6
I have a 2016 SS Agile that had the same configuration. The LW3000-12-C failed in such a way that it would not connect shore power to the internal systems like the air conditioner. This resulted in my wife and I driving through the night to get home because we had no air conditioning on a hot night.
I found The Inverter Store sells a unit by AIMS that is form, fit, and function compatible with the LW3000. It is pricey (about $400 higher than I paid) but is relatively easy to install. A minor modification had to be made to the remote panel wiring.
Link: https://www.aimscorp.net/3000-Watt-P...r-Charger.html
I have purchased the components and cable to install a manual switch that will allow me to bypass the inverter/charger to get shore power. It is an insurance policy to guarantee connection of shore power and if necessary use an external battery charger to maintain the batteries. When these integrated units fail, the results can leave you with nothing.
Jim Agile is offline   Reply With Quote
Old 08-05-2022, 12:47 AM   #7
Here's a link to the AIMS unit at a lower price:
https://factorypure.com/collections/...er-charger-new
Old 08-05-2022, 01:25 AM   #8
Be careful with a manual switch to bypass the inverter internal transfer switch. Depending on how everything is wired and how many poles the added switch has, you could stand a risk of having both the inverter output on and shore power on to same outlets with double neutral ground bonding likely. The transfer switch in the inverter will switch both hot and ground between the two sources, and you won't know what is closed or open inside it.
Old 08-05-2022, 02:15 AM   #9
Your are correct. I was able to locate a 3 pole switch that can do the job...
https://www.amazon.com/Baomain-Unive...72668131&psc=1
Thread Tools
Display Modes
