Old 10-13-2021, 12:40 AM   #1
Default Question about modern ACR's
With an old-school solenoid battery separator, the engine battery will not receive a charge if the ignition is off and the onboard (shore power) charger is working. This is because the 2 batteries are physically disconnected by the solenoid and only the house battery receives a charge. But is this the case with modern ACR's? With a modern ACR, I think both batteries will receive a charge when the onboard (shore power) charger is working. Is this correct? - Thanks
Old 10-13-2021, 12:56 AM   #2
They can be one way like an isolator or two way automatic like most are now so both batteries charge if either side is on charge voltage. You can also get full manual control from a switch that is off/on/or auto for the connection.
Check out the Blue Sea site for details, they make very good stuff.
Old 10-13-2021, 10:19 PM   #3
I installed a Blue Sea model number 7610 ACR that also has starter interrupt that disconnects the two sets of batteries when the starter kicks in to avoid bid draws through the relay.
https://amazon.com/Blue-Sea-Systems-...94&sr=8-1&th=1
Old 10-17-2021, 10:51 PM   #4
Booster... Putting a 7610 in our 2003C190V Roadtrek.. I seem to recall a post you were in that suggested putting it in parallel with existing isolator.
I lke that idea ... do any wires from the isolator need relocated and is there a Ground in the original that can be to jumpered to (or repurposed as) the Gnd needed by the 7610 ? And is the start isolation highly advised, or just a nicety?
TIA
78000 mi
Road Toad is offline   Reply With Quote
Old 10-17-2021, 11:00 PM   #5
TIA
I don't think that was me for parallel with an isolator but there have been lots of posts. I have used 7610s in a special way with a Blue Sea charger to control outputs, but never as a primary connection to the engine as they are too small for our charging system. We use the manual remote on/off 300 amps Blue Sea.
Ignition interrupt is probably a marine thing as I don't ever recall it needed in RVs. I used as a relay switch and it also works for that, though.
I think the the merit of parallel was that those that wanted to do it could get full charge voltage through the ACR and then shut it off and get the .7v drop through the isolator for float during driving.
Old 10-18-2021, 02:46 AM   #6
Maybe itwas Marco or one of the other knowledgables ..
Tks
78000 mi
