Old 07-01-2022, 08:47 PM   #1
jls
Default Rocker switch plug-n-play replacement
Looking to replace a broke rocker switch on my 2020 Roadtrek SS Agile. It's the blue lit one that controls the water pump. Already tried a NAPA auto parts store and it was a close but not quite fit. Anyone know a source online?
jls is offline   Reply With Quote
Old 07-01-2022, 09:14 PM   #2
likely your switch has a manufacturers code marked on it and you can search for same.
if you see a 6 or 7 digit code, EIA uses the first 3 digits for manufacturer (the other digits are date code) which you can find by googling
( EIA codes are on almost all us made electronic parts, and on many parts made for use in the US market )
other wise measure it and head for amazon which has a much wider selection
mike
Old 07-01-2022, 11:53 PM   #3
Try this site https://www.delcity.net/store/Switches/
Old 07-03-2022, 09:17 PM   #4
jls
thank you. they seem to be Sigma rocker switches, available here:
https://www.sigmaswitches.com
