start by checking the source at your house and then work towards the van.
if this is beyond you ( and that's ok! )
check the source at the house and if that checks good take the van with your cable to an RV shop.
if you have a meter you can check the cable which plugs into the van- assuming a twist lock connector, there are 3 poles:
the "L" shaped is GROUND
the larger of the 2 slots is NEUTRAL
the smaller of the slots is HOT
measuring with your probes, you should see:
Hot to Ground: 120 volts ( nominal value- anywhere between 110~130 volts)
Hot to Neutral: same value as above ... within 5 volts
Neutral to Ground: close to 0, as much as 5 volts is acceptable
