Old 09-21-2020, 05:20 PM   #1
Default Need advice - replacing waste dump valve
I just bought a 1999 PleasureWay that someone put electronic waste dump valves on that do not work. I want to replace them with manual valves. What are the best ones to get?
Dianne D is offline   Reply With Quote
Old 09-21-2020, 05:23 PM   #2
most of us use the valterra
there is another thread where people are expressing their results with the valterra. good/indifferent/ and bad
I replaced mine a few years ago and they are fine.the need to be lubed on install- I use plumbers grease ( 160ºF melting point) I also changed the way the bolts run so that next time I can swap more easily- someone put it on the "hard way"
Old 09-21-2020, 05:57 PM   #3
Thanks so much!
Old 09-29-2020, 10:27 PM   #4
I concur as to Valterra.
Plus on these threads there is a simple modification that ensures your valves stay lubricated with more ease of use with less opportunity for failure.
