Old 10-25-2020, 05:56 PM   #1
Default Overfilled diesel
Hello. I just overfilled my sprinter with diesel. It was actually spouting out once I stopped it. I see now the issues after googling it. Will this dry out and run? Or do I need to be towed.
Stuck on side of road, as it won’t start now. Still the newbie.
Bill Kimball is offline   Reply With Quote
Old 10-25-2020, 06:34 PM   #2
Sorry to hear of your trouble Bill.
I don't have a diesel model but I'm replying to bump up your post for others to see. Tough that it is on a Sunday, but you probably want to call for a tow to a Sorinter repair shop to get it and your family off the side of the road as soon as possible.
Please be specific on your tow request so they send only a full carrier tow truck (not one that just picks up the front end) and stress repeatedly that it is an rv so they send a tow truck with a bed long enough and strong enough to handle the weight. Otherwise, they might only send one for a standard Sprinter van.
Interblog posted her towing tale of woe a year or so ago.
Old 10-25-2020, 06:46 PM   #3
Thanks very much. Tow truck on its way.
Old 10-25-2020, 06:55 PM   #4
Did you put diesel in it, or did you maybe put gas, or maybe def in it? Overfilling should not keep it from running!!!
Old 10-25-2020, 06:58 PM   #5
I was wondering the same thing. What did you read on the Internet concerning no-starts due to fuel overfill? Does it damage the evap system or something?
Old 10-25-2020, 07:31 PM   #6
I had my diesel tank overfilled once due to a malfunctioning nozzle and lack of attendance, a little clean up and we were on our way.
Old 10-25-2020, 07:59 PM   #7
DUTCH in Atlanta's Avatar
There is something not apparent with the OP's post.
I have over filled my Sprinter diesel many times - especially when filling with a truck nozzle.
Never a problem of starting up and driving away.
Old 11-01-2020, 04:55 PM   #8
I agree that this sounds like more than overfilling. One thing I learned very early with our Sprinter is to never set the nozzle flow adjuster to anything other then low, and to watch it like a hawk. Early on, I had a couple of overfills where the nozzle did not shut off, and so I live with a slower fill and watching the thing.
mechmike10 is offline   Reply With Quote
Old 11-01-2020, 06:55 PM   #9
I agree, there should be no problem with starting just because one overflowed upon filling with diesel. Must be another problem.
Douglas O. Culpepper
docman5 is offline   Reply With Quote
Old 11-01-2020, 09:57 PM   #10
Default Probably Not Overfilling Problem
Yeah, we have a Sprinter and have badly overfilled it when a pump nozzle stuck, too. Ran fine after.
Ray B is offline   Reply With Quote
Old 11-04-2020, 05:25 PM   #11
I too have overfilled when the nozzle didn't shut down. I hadn't had a problem after. I am leery of any pump island now that has diesel staining on the ground.
Old 11-04-2020, 06:13 PM   #12
I've never seen one that didn't have diesel staining on the ground, especially if the pump has a truck nozzle.
Old 11-04-2020, 07:53 PM   #13
I avoid truck nozzles as well. I never go to the islands dedicated for the semis.
Old 11-04-2020, 08:05 PM   #14
Sometimes there is no alternative. Been to lots of those.
Old 11-04-2020, 08:12 PM   #15
They are handy when you need a DEF fill-up. If it is a busy truck stop, you can be pretty confident that the fluid at the DEF pump is fresh.
overfilled diesel
