Old 05-01-2021, 04:43 PM   #1
Default new here
Just purchased a 2003 Ford Pleasure Way, wondering if anyone has change the carpet
lasee3637 is offline   Reply With Quote
Old 05-01-2021, 09:23 PM   #2
Default New carpet
Just finished replacing the flooring in our 2006 Excel.
Put vinyl plank in the living area and new carpet up front. Lots of staples in the carpet and lots of glue on the linoleum.
Also installed loncoin in the step well.
Gimblerotor is offline   Reply With Quote
Old 05-01-2021, 09:31 PM   #3
is there a plywood under layment under the PW flooring in that model?
nice looking work
mike
Old 05-01-2021, 09:49 PM   #4
The floor is all plywood up to where the vinyl plank ends.
Old 05-03-2021, 10:30 AM   #5
I mentioned the vinyl plank to my better half, yours looks great. Did you take out the captain seats to replace the carpet
Old 05-03-2021, 11:55 AM   #6
I did remove the seats but left the swivel base. There are 4 14mm nuts and a wire connector.
I also under cut the trim so the plank would slide underneath.
Old 05-03-2021, 12:06 PM   #7
on my chev, I replaced the seat base foam last year ( YAY!)
while there I cleaned out the old crusty lube and gunk
and relubed
much smoother, easier
thanks for answer on the plywood...food for thought. so far our flooring is good, but dog hair ( really mine falling out) and sand and pine needles make me want easier cleaning
Old 05-13-2021, 06:28 PM   #8
Wow, Gimblerotor, that is gorgeous!
You've got me wanting to rip out that back carpet, too!
My wife wants me to remove the table base from the floor in back because it sticks up and we trip on it, and buy a portable tripod base. You get the added advantage of being able to take the table outside.
MarkS is offline   Reply With Quote
Old 05-13-2021, 07:20 PM   #9
Thanks for the compliment. You should go for it. It’s not that hard to do. If you remove the table base you have to plug the hole with something. It goes all the way through the floor.
Jake
Thread Tools
Display Modes
