Old 01-17-2021, 03:04 AM   #1
Default 2007 Sprinter dome light fixture removal
Hi All,
I'm attempting to remove the complete fixture that is attached to the bump on the ceiling. I'd like to drill-out a hole in the fixture for a toggle switch that controls my aux lights. For the life of me, I cannot figure this out! I've removed the translucent lens and light, so now I have an access hole. But, I'm stuck. This is a 2007 model year, which happens to be a Freightliner. Please, help!
-David
david@davidfischer.com is offline   Reply With Quote
Old 01-17-2021, 07:11 PM   #2
The dome light is just spring loaded into the fibre head liner. Put a small screw driver under it and it should just pop out. I had mine out to put a toggle switch beside it for my backup camera when I owned the Sprinter.
Ken
_____________________________________________
2021 Ford Transit AWD ‘Iron Horse’
Formerly - 2007 Pleasure Way Plateau (06 Sprinter T1N), 1992 VW Eurovan Westfalia Hightop
Long ago - 1969 VW Westfalia & 1973 GMC Motorhome
ks@yvr is offline   Reply With Quote
Old 01-31-2021, 05:13 PM   #3
The spring clips (2) are on the right (passenger) side of the dome light module and can be seen by pulling down on the module slightly. Then insert a flat blade screwdriver to push each clip inward. The module will then swing down on the passenger side, with the driver side acting like a hinge. This is the way it is designed on my 2014 MB Sprinter and I assume the the 2007 is the same or similar.
DaveWA is offline   Reply With Quote
dome light fixture
