Old 07-13-2020, 01:29 AM   #1
Default Aftermarket TPMS HI/LO & Temp Alarm Settings
Have bought, but yet to install an aftermarket TPMS.
1999 RT 190 Popular. 65 PSI front, 80 PSI rear.
This monitor allows different alarm set points for front and rear tires.
I'd like some guidelines on LO alarm, HI alarm, and Hi Temp alarm set points.
These are external (valve stem) monitors and I don't know if the temperature readings will be accurate, but am more concerned about low pressure alarms. It also has a sudden pressure loss alarm.
Thanks, Ed
1999 Roadtrek Popular 190
Dodge 3500 chassis
RedPanEd is offline   Reply With Quote
Old 07-13-2020, 01:36 AM   #2
I use a similar but $38.
Works fine for 80/60 and temps seem good
my prime reason is to watch tires for sudden PSI loss after hitting road debris
the best mounting for my unit was on the inside of the windshield in the upper corner
I use USB for power and once charged the solar will maintain ok
I live in PHX and see high tire temps I have not set alarms for temps
I have the alarm setting for PSI at 50 PSI which would show a loss of 10 psi front and 30 psi rear
Old 07-13-2020, 12:58 PM   #3
I run 62 PSI front & 80 PSI rear.
Use the weight of each end or corner of the van and the load and inflation table for your particular tire to find the minimum PSI required to support the weight.
For my van, those minimums are approximately 65 PSI rear & 50 PSI front. My low pressure alarms are set above the minimum requirement and are 70 PSI rear & 55 PSI front.
My high pressure alarms are currently 95 PSI rear & 75 PSI front. I'll probably lower those a bit. I want it high enough to prevent unneeded alarms but still be useful.
The Tymate linked to in the first post lists the range as 0-87 psi - if the max alarm setting is 87 psi then it is probably a bit too low for most Class B vans. The tire pressure could exceed that as the tire heats up while driving. A PSI setting of approximately 10% over should be OK (in theory) from what I've read but you'll probably find that you often start the trip already over 80 psi if the pressure was set in the morning when the ambient temperature was much cooler. A PSI setting of approximately 15% over should avoid nuisance alarms.
My rear tires reached 85.9 psi on a 15 mile / 20 minute / back roads / somewhat overcast but high 70's ambient temperature trip a few days ago.
I left the high temperature alarm at the default setting.
Old 07-13-2020, 01:14 PM   #4
Not on the temp numbers, but something that is very interesting concerning the minimum pressure rating charts.
As we often stress, this is the minimum pressure you should run, not the best for ride/handling balance or even safety, and Marko, like most of use is running higher than the chart pressures.
The interesting part is that the pressures he has chosen to use are at the essentially same ratio of pressure front/rear at 77%.
We have found that for best handling/ride balance we run 62/76 psi. Our interesting part is similar to Marko's. Our ratio is 81% and that is also the front/rear axle weight ratio for us.
I need to check the minimum pressure chart to see if that gives the same ratio for ours, I think, to see if it is the same also. If all three of those are the same, it kind simplifies narrowing in on the best tire pressures for individual vans, I think.
Thread Tools
Display Modes
