RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 01-24-2021, 04:12 AM   #1
Default Armrest Adjustment
Has anyone adjusted the front captains chair arm rest up to level it? I have one armrest that is leaning downward. I have a 2006 Chevy 190 Versatile with the Roadtrek captains chairs. Thanks in advance.
55 Nomad is offline   Reply With Quote
Old 01-24-2021, 02:11 PM   #2
Jon in AZ's Avatar
I’ve noticed on my 2014 RT190P that the inboard armrests are very solid and the outboard are somewhat flimsy and sag. I did a little checking by pulling back the covers, and the inboard ones appear to be factory armrests from Chevy, while the outboard ones were added by Roadtrek. I didn’t discover any obvious way to adjust or snug up the outboard ones, so I’ll be following this thread so see what others have found.
Old 01-24-2021, 02:23 PM   #3
This post: https://www.classbforum.com/forums/f....html#post5555 probably won't help but still worth trying. If the armrest can be taken off as I described or by a similar method then you might have a better chance figuring out how to adjust it.
Two bikes on sliding cargo box: https://www.classbforum.com/forums/m...icture206.html & 1997 GMC Savana 6.5L Turbo Diesel Custom Camper Van Specifications: https://www.classbforum.com/forums/f...vana-5864.html
Old 01-24-2021, 03:23 PM   #4
Mine is the drivers inboard. The others are good.
Old 01-24-2021, 03:54 PM   #5
Jon in AZ's Avatar
Have you unzipped the cover to look underneath? I think you’ll find a stock Chevy armrest, but I can’t remember if there’s an easy-to-access bolt. If so the usual procedure is loosen, adjust, retighten. My issues were with the outboard so I didn’t pay that much attention, but that’s how they worked on a previous minivan we owned.
2014 Roadtrek 190 Popular
2008 Scamp 13
Old 01-24-2021, 04:50 PM   #6
there is single screw to remove armrest.
there is a toothed spindle - on my 05 chassis chev it was indexed and armrest could only go back on in one position.
removing the index with a dremel could possibly allow the armrest to be rotated back or forward a tooth
it could be that the real fix is to remove the seat covering and see what is happening internally either wear or a loose positioning screw
I had mine off to refoam my seats- and didn't take time, or need to, look at this internal assembly
getting inside the seats is pretty easy - you tube
if doing this maybe a good time to clean out old lube & relube the seat swivel
mike
Old 01-24-2021, 06:41 PM   #7
My 78 Chevy G20 Nomad van with the factory captains seat had an adjustment screw and stop under the armrest. Easy adjustment. These seats are not like that that I can see.
Thread Tools
Display Modes
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
