Old 01-14-2021, 09:17 PM   #1
Default DC lights flickering when on shore power.
I have a 98C200V with the old Magnetek 6345 converter/power center. It works well, however, my dc light bulbs all flicker/pulsate when the ac charger is on. I am planning to replace the guts eventually, maybe sooner rather than later. It drives me nuts, like a strobe light. Anything I can do about this?
They are LED bulbs in the original fixtures...
Thanks!
KaptainK is offline   Reply With Quote
Old 01-15-2021, 12:03 PM   #2
I had problems with the first round of LED bulbs. What I found out is that they were rated for 12 volts. When the charger is running the system has more than 12 volts. I found bulbs that had a voltage range, I think something like 8 to 16 volts. These worked fine.
In your case it's also possible that the charger/converter could be an issue as the original unit introduces unfiltered DC current. That might be an issue with LED's.
I would make it a high priority to install a modern charger/converter. I used a Progressive Dynamics PD4645. Not crazy money, relatively easy to install, decent charge profiles(though not the best*) and assembled in the USA. The battery in my RT when I sold it was a group 29DC from Wally World, the Maxx version. After 2.5 years of use it was still performing well using the PD4645 and solar, boondocking about 4 months per year.
*The best($$$) chargers entail using tail current for charging control.
Old 01-15-2021, 01:36 PM   #3
I'd put a voltmeter on and see what voltage is being provided to the DC circuits- and see if anything is loading the circuit in a cyclical pattern, drawing the voltage down
so is it the dc power provided?
or a device drawing power?
Old 01-15-2021, 01:44 PM   #4
Seems to be just the led bulbs in the old fixtures. Most have been replaced already with LED fixtures. They all work just fine. I ordered a PD 4645 after posting this last night.
Old 01-15-2021, 01:56 PM   #5
Check the quality of your grounds. I had a similar problem when our Espar was starting up (a high-current situation). Improving the Espar's ground fixed 99% of the problem.
Old 01-21-2021, 05:19 PM   #6
I current have the same issue on a 99P190. Flickering stops with high enough load on the battery. DVM shows a very high AC voltage riding on the DC, about 12V. I have not yet fixed it, but am assuming one of the rectifying diodes in the Magnetek has shorted.
ChipWeller is offline   Reply With Quote
Old 01-21-2021, 06:46 PM   #7
Disconnect shore power, turn.your battery switch on before.pluggimg back into shore power. That should stop.the flickering.
Dougm38 is offline   Reply With Quote
Old 01-21-2021, 08:09 PM   #8
Problem solved. Put the PD6445V converter in. Works great!
File Type: jpg EB1FA1DE-60B6-44ED-A790-B164E33017CA.jpg (292.5 KB, 15 views)
Thread Tools
Display Modes
