Old 05-14-2021, 12:57 AM   #1
Default Floor Panel between Driver and Passenger Seat
We have a 2018 Lexor on the 2017 Promaster 3500. My wife has asked me what is under the floor panel between the Driver and Passenger seats. She is concerned that it is soft and we could be damaging something when we step on the panel. I have done some searching but haven't found anything yet. I know it is not the battery compartment. Next step would be to ask the mechanic in a couple of weeks. Thanks
RMLetstryrving is offline   Reply With Quote
Old 05-14-2021, 01:53 AM   #2
Does your model have any of the under-floor storage doors or drawers you can remove to peek underneath?
Old 05-14-2021, 12:54 PM   #3
Jon in AZ's Avatar
You could also call Pleasure-Way.
Old 05-14-2021, 01:00 PM   #4
eric1514's Avatar
There's nothing but factory floor in the Travato. The rubber mat Ram uses is very squishy. Remove the portion covering the battery and you'll see, at least on mine, that mat is about an inch thick and very soft.
"Il Travato Rosso"
2015 Travato 59g
Old 05-14-2021, 01:05 PM   #5
mloganusda's Avatar
2017 Trend and ProMaster drivetrain. The soft cover is over the gas tank and if removed you will see the out lines for the fuel to the engine and also one for a generator. On home built units there is an extra line for connection for a generator fuel line, and this line is only 3/4 down into the tank to keep generator from emptying gas tank and leaving you stranded.
Old 05-14-2021, 01:11 PM   #6
The gas tank in under the front seats?
Old 05-14-2021, 01:31 PM   #7
Yes.
We tapped into that port for the Webasto gas heater. Very convenient.
Don’t worry about the squish. You won’t hurt anything. I suggest this floor mat which will give you a nice uniform surface. After nearly seven years, mine looks as good as the day it was laid. It always lies completely flat—corners never curl.
https://www.eurocampers.com/1-piece-...it_p_1214.html
Light grey is a good color. In real life, it is almost the color of the floor.
Old 05-21-2021, 01:08 PM   #8
I'm not sure if it helps, but I have a 09 PW Chevy Lexor TS and when I had the flooring replaced there were wires in that section. I know they had some issues working around it, so I guess paying a professional, not something I usually do, in this case it paid off.
Thread Tools
Display Modes
