11-30-2021, 05:22 PM
Images of Roadtrek 190 with lower fiberglass skirt removed
Interested in seeing what my rig would look like with not only the fiberglass door panels* removed but more importantly, the whole lower fiberglass that covers the tanks & bumpers removed.
*I have already found many photos that show the door panels removed.
As it is, I have two claims into AAA for damage that happened (Hit & Run here in Los Angeles) during Covid & the Roadtrek saga* where both bumpers are cracked but also a couple of side panels & lower supports.
*took it to the local Roadtrek dealer but couldn't get an answer.
Two other times over 10 years when I had lower fairings repaired, they tried to write off the rig for Salvage Value & it was a battle - this time I might let them do it, buy the rig back, take off the vulnerable skirts & drive without them.
These photos included are NOT of my rig but it's same year & only show the even more vulnerable door panels removed
I do know that I would probably lose the valuable storage on the driver's side if removed.
11-30-2021, 05:30 PM
That area will look very much like a Roadtrek 190 Simplicity, I think. AFAIR they all came without the door cladding a bumper covers.
11-30-2021, 06:04 PM
Booster,
I just looked at a couple Simplicity images & it appears they have a different skirt - I am assuming it's going to be ugly underneath on my 190 but anytime they touch those lower panels, its a $15,000 insurance bill
11-30-2021, 06:13 PM
They do have the behind the rear wheels pieces gone also, probably because those are made to blend to the bumper cover. The running board it self could be a bit different, probably at the upper edge where would meet the door panel if it had them.
There is also the thing that there was a change in all the skirting, I think somewhere around 2006 or 2007, so that might make it different than an older one.
12-01-2021, 04:26 PM
Food for thought ... Mobilife RV in Kitchener, Ontario has an inventory of Roadtrek parts from the "good old days".
12-01-2021, 06:39 PM
I was thinking this time. I will let them bully me into a Salvage Deal, writing me a check for $30k & buying it back for $5k
Thread Tools |
Display Modes |
Linear Mode
