Old 12-06-2006, 12:21 AM   #1
Jardinier's Avatar
Default Importing data in Microsoft Street & Trips
Importing mapping coordinates in Microsoft Street and Trips allows you to visualize points of interest and waypoints on each map you will create. To do so, a new template must be created unless you only want specific data to apply only to certain maps. Microsoft Street and Trips uses a template for all its maps. It is easier to build a template with a copy of the one included with the software and add data to it. You will normally find this template in C:\Program Files\Microsoft Streets & Trips\Templates under the name “New North American Map.stt”. You can copy of this file andsave using the name “Copy_of_New North American Map.stt” just in case. Data will be imported in the original template file.
Here’s the web page where you can download data files for various GPS applications (Delorme, CoPilot and Microsoft Street and Trips). http://www.discoveryowners.com/cginfolinks.htm
In the first column, you have a short description of these files. They are available in WinZip file format. Microsoft Street and Trip’s files appear in the last column
Download those you want to import (right clicking of the mouse).Once the file unzipped, have a look at them using notepad (faster to load). Some may need a preliminary cleanup or editing before importing them. For example, they might have email addresses or blank lines or other information which will not be imported in MST. Here’s an example of two lines from one of these files:
FL Florida City 1/07
26.546919,-81.789593, Ft Myers FL x131.
The first line is an example of useless data, so it can be removed. Some files contain column titles or headings in the first row. If not, you can add a new first row containing these headings. Usually, the first value corresponds to the latitude, the second to the longitude and the third one to a description of the data. MST will recognize them if you use the terms “latitude, “longitude, name”, the first two separated by a comma. The second line contains the actual data. Each value, latitude, longitude and description, in this file is separated by a comma and is the equivalent of a column cell. Once the cleanup done and the edited file saved, your are now ready to import it MST.
Open the application and open your “New North American Map.stt” template. Don’t double click it. This will only create a new file in the application. Once opened, select “Import Data Wizard...” from the "Data" menu. A dialog box will appear asking you to open the data file you want to import. Once you have selected it, another dialogue box will ask you specify what character separates the values. Since MST already read your file, it detected a character for you to confirm.
  • [list:q4ar0jib]
[/list:u:q4ar0jib]
Click the “Next” button.
The next dialog box will ask you to determine the country or region of your data. Choose the concerned country from the list. It also contains a small option box you will select or not depending if the first row contains the actual heading of each column.
  • [list:q4ar0jib]
[/list:u:q4ar0jib]
  • [list:q4ar0jib]
[/list:u:q4ar0jib]
If no headings were given, you must select the appropriate heading for each comma separated value or column MST has detected. A list of headings for you to choose from appears in a drop down menu under each column of values. Unless otherwise specified by the creator of the data file, select “latitude” from the first list, “longitude” from the second list and “name” from the third list. If you don’t know what the content of any other column is or can’t find an appropriate type from the list, select <Other Data> indicating MST not to import the column.
Once all columns have been identified, click the “Finish” button.
  • [list:q4ar0jib]
[/list:u:q4ar0jib]
Depending on the volume of data imported, the map will be covered with pushpins. As you zoom in they spread out and let you have a better view of the information displayed on the map.
Save the template file.
By default, each set of data uses the same pushpin. You can change to a different symbol either from the “Legend and Overview” sub-menu under “View” or directly from any given pushpin of a set.
  • Legend and Overview: Right-click a set under “Pushpin” and select “Properties” from the contextual menu. In the dialog box, click “Symbol” to choose one of the symbols or to import a custom made symbol of your own (must be a .ico, .bmp or .png file). If you import a symbol, you have to select it once it appears in the list of symbols.
    Right clicking a pushpin: Select “Properties” from the contextual menu. In the dialog box, click “Symbol” to choose one of the symbols or to import a custom made symbol of your own (must be a .ico, .bmp or .png file). If you import a symbol, you have to select it once it appears in the list of symbols.
  • [list:q4ar0jib]
[/list:u:q4ar0jib]
Here's a link to download my custom symbols :
http://www3.sympatico.ca/danielle_pa...om_Symbols.zip
After choosing your symbols, save the file again.
Note that the « Properties » dialog box also give you other possibilities such as using a different name for the set than the name of the file you imported. You can also decide which column will be displayed in the balloon when you right-click on a pushpin and select “Show information” in the contextual menu.
  • [list:q4ar0jib]
[/list:u:q4ar0jib]
1998 Roadtrek 200 Versatile.
Skype user.
Jardinier is offline   Reply With Quote
Old 12-06-2006, 02:28 AM   #2
Thank you for posting this Jardinier. This was a lot of work. You had mentioned to me that you were working on this and had to translate it from French. This will be useful to people for a long time.
Before I started I made a copy of the New North American Map.stt as you suggested.
I used your instructions step by step and it worked exactly as you described. I imported the Oregon State Parks from the link you provided.
I chose to save that new map as Oregon State Parks.stt when I was finished.
With my Streets & Trips 2005 it seems to me that importing new data like this will extend the life of my 2005 version a bit longer.
This is useful even if you don't have a GPS. (I don't have one) Your custom icons are a really nice touch.
Thanks again.
Old 12-06-2006, 03:14 AM   #3
Jardinier's Avatar
Hi marcopolo,
One of the icons I made in the zipped symbol file was originally designed for the State Parks allowing RVs. It's a miniature tree. Since you created a template specificly for Oregon State parks, you can import that symbol as a pushpin for OSPs. I'll add an Oregon State Parks symbol in my zipped file. In the meantime, I'll try to send it directly to you.
Take care
Skype user.
Old 12-06-2006, 04:17 AM   #4
Got it, thanks.
Old 12-06-2006, 04:22 AM   #5
Jardinier's Avatar
Surely looks fine!
Skype user.
