Old 11-20-2021, 05:18 PM   #1
Default Limited Slip or Locking Differential Value?
Would a limited slip rear axle make a big difference in slippery/muddy conditions? Better yet, in my mind, is a remote control locking rear differential.
I have thought that if the rear end goes out on my Roadtrek 210 I would: 1. get a full floating axle, and 2. get limited slip, or remote locking differential.
Lots of articles. Here is an interesting (perhaps biased) view of 4W traction control versus a locking differential.
https://outbackjoe.com/macho-diverti...ction-control/
I decided to start a separate thread from this interesting discussion:
https://www.classbforum.com/forums/f...tml#post134216
Old 11-20-2021, 06:01 PM   #2
Here is one I started quite a while ago on lockers vs 4 wheel drive without lockers.
https://www.classbforum.com/forums/f...tial-7498.html
Old 11-20-2021, 06:11 PM   #3
Now I remember that discussion. Should have done a search
Old 11-20-2021, 07:49 PM   #4
Just came across this discussion on adding a locking diff to the Chevy Express. Too bad none of the posters actually did the swap to see how it worked.
https://www.sportsmobileforum.com/fo...ess-25012.html
Old 11-20-2021, 08:54 PM   #5
I am not positive, but I think the 10.5" axle used in the vans changed around 2010 to a GM 14 bolt version which I think is made by American Axle. Lockers may be more available for them and they should still be a bolt in unit.
Old 11-25-2021, 03:55 PM   #6
I grew up driving rear wheel drive cars in wintry conditions even though I now live on the west (wet) coast. My experience with limited slip is that you get far better traction when starting out and getting unstick. However if you use your right foot liberally, a limited slip car will fishtail MORE on corners since both rear wheels will spin, not just one. I like a controllable oversteering car, but you do have to be careful with the throttle on corners.
Bertiboo is offline   Reply With Quote
Old 11-25-2021, 04:04 PM   #7
LSD's and locking diffs are only good where one rear wheel slips, and the other on good traction. Like when one wheel moves off pavement while the other remains on pavement. Also helpful on steep wet inclines. But that's simply my 55 years of experience.
Old 11-25-2021, 04:57 PM   #8
I would sort of agree with this but I think it does understate the capabilities of a good LSD or locker. There are numerous styles of both and all function a bit differently.
Most think of an LSD as the normal type we all had in the past. They are simple spring loaded clutches tying the two side of the differential together. They can be setup to be not, lightly, or tightly engaged in regular driving. Both wheels will drive more or less on less slippery depending on how tight they are. Tighter means locked more tightly on turns and more likely fishtailing for instance on slippery surfaces. Putting power on in a turn will often make the inside tire squeal or chirp a bit. They are not capable in most cases of being able to transfer all the power to wheel that has traction, however, as the clutches don't hold that tight.
There are helical gear LSDs also that use no clutches, just two sets of helical gears. When a power per side difference is seen, the slowest turning side gains more power. They can also be set tight or loose to be mostly unengaged or just a bit snug so less likely to fishtail on slippery stuff unless power is going on. Once they get to the speed difference to start to lock, more power tightens them very quickly with more power. I have one in my 96 Buick Roadmaster and it is seamless in normal driving unless I get on the power in a tight turn, then it chirps the inside rear tire.
Lockers come in two main styles plus the oddball GM Govlock setup. Full time lockers are just that, they are locked all the time except when turning forces on good traction surfaces generates enough force to make them ratchet. They are killers on slippery surfaces and nearly impossible to keep in a straight line. Manual lockers use either electric or compressed air to lock to two sides together only when you tell them to. They are great in all conditions as they don't ever lock unless you want them locked. The Govlock is a full locker that runs in unlocked mode until you get 100-200 rpm difference in wheel speed then locks solid but will unlock with enough force difference just like a full time locker. They also unlock above about 20 mph no matter how much speed difference so much safer that way. They are great, but have had some reliability, especially in the under 10.5" ring gear lower capacity axles.
My choice for a class B would a electrically operated manual locker first, then a Govlock, then a helical gear LSD, then a clutch type LSD. Of course there are lots of other opinions on all of this.
Old 11-26-2021, 01:36 PM   #9
@Michael's Avatar
Originally Posted by Bertiboo View Post
...if you use your right foot liberally, a limited slip car will fishtail MORE on corners since both rear wheels will spin, not just one. I like a controllable oversteering car, but you do have to be careful with the throttle on corners.
Yep - which is why LSD's are more fun when spinning donuts in a snow-covered parking lot.
LSD's can be useful on forest service roads, in mud, sand and other low-traction situations also.
2019 Coachmen Crossfit
