Old 08-12-2020, 08:05 PM   #21
Not sure about the antenna. My unit has a crank up antenna, but I've never been able to pick up anything with it. Between wifi and hotspot, I've been able to watch most anything I want. And the DVD player of course.
kojo is offline   Reply With Quote
Old 08-12-2020, 08:37 PM   #22
Currently it is plugged into a 12V socket....and there are so many wires and cables behind it, I have no idea what else they do. Obviously, I'd like to just plug it into the current plug for now and then look at other options down the road. Thanks
terance13 is offline   Reply With Quote
Old 08-12-2020, 08:38 PM   #23
And what TV do you have and how is it powered?
Old 08-12-2020, 09:55 PM   #24
do you have an antenna amplifier which needs to be turned on?
Many rvs need amp turned on when not on campground cable
from my driveway I pick up the tucson stations - the transmitting antennas are 108 miles away
mike
Old 08-13-2020, 06:06 AM   #25
roadbiker1's Avatar
my 2008 Pop has a RF select switch to choose either the Winegard external antenna OR a stub of coax to connect to local cable. My switch is up in a L side top cabinet near the Winegard antenna amp. If the ant amp shows power ( little LED ) and the TV still has nothing, maybe flip the RF select to the other position. Cheers.
roadbiker1 is offline   Reply With Quote
Old 08-13-2020, 11:07 AM   #26
Wandering Wes's Avatar
If your TV is over 10 years old you need a “Digital Adapter” to be able to get a signal.
Buy one for about $25.00 at Walmart. It has a remote and the ability to record.
Wandering Wes
2010 Pleasure-way Excel TS
Never a problem, Sometimes a challenge, Always an adventure.
Wandering Wes is offline   Reply With Quote
Old 08-13-2020, 06:51 PM   #27
I'll look for it...how do I post a photo/video to a post or reply? I'll take a photo of what I have and post it. Thanks
Old 08-14-2020, 12:00 AM   #28
I feel a little silly.
I never watch TV.
But I do edit go pro Motorcycle Videos & watch rugby & rugby league - I have a 48 inch Samsung Smart TV in my Roadtrek Versatile...
Old 08-15-2020, 07:46 PM   #29
Thanks everyone for your advice. I'm going to keep the TV we have and buy a Firestick...my wife says she knows how to set her iPhone to be hot spot and we will go from there!
Old 08-15-2020, 09:24 PM   #30
The Firestick / iPhone works great for me. Just remember, the Firestick works on an HDMI jack. If your TV doesn't have one, you will need to buy an HDMI to RCA adapter. They are fairly cheap and you can get one on Amazon.
Old 08-16-2020, 01:56 AM   #31
It does have a HDMI port...thanks!
Old 12-25-2020, 01:41 AM   #32
posh button light will come on that is the amplifier.
robert g is offline   Reply With Quote
Old 12-25-2020, 01:44 AM   #33
push button light will come on that is the amplifier.
Old 12-29-2020, 01:02 PM   #34
Default Tzumi Magic TV tuner for smartphones and tablets
For Apple devices (the only one that I can find, there are others that work with Android). It does not require an external WiFi connection. It talks to the monitor via a WiFi connect between the tuner and the device. It works as well as the strength of your airwaves allow. I find them new-in-box for thirty dollars on eBay.
It looks like Tzumi does not make them any longer.
File Type: jpeg 7E50DFFC-7833-4435-8D71-E12E5F6E2DDA.jpeg (304.6 KB, 4 views)
CraigX is offline   Reply With Quote
