05-17-2020, 06:25 PM
Pleasure Way on 2005 Chev 3500 seat foam AND bed foam replacement
a couple of 12 hour days in the saddle- it's clear my seat is breaking down
youtube shows that new foam install is a snap, but I am looking if anyone has already done this
I don't know if Pleasure Way uses stock seat and just uses own covers, or if they change/reshape foam
if stock,
my choices are GM #88982034 at about $70 each
or some other aftermarket knockoff
or "the seat shop" durofoam for about $120 ( amazon or direct)- these are higher density, but not sure if that would be a plus or minus for long days- add that the 2 seats swivel and are the only seat so get use when parked
anyone done this yet?
I am also looking to redo the rear benches/beds- anyone have specific foam product suggestions?
Covers are good so should be easy job, just want the best product for comfort
thanks Mike
05-20-2020, 05:43 PM
I've ordered the seat shop lower pads for $125 ea on amazon.
Will update once they arrive and I install
No response from Pleasure Way to questions asking if the seats have stock GM or modified by them seat pads (shame on them, the current owner is their best sales person)- so if there is a change, Amazon makes for easy return
mike
05-21-2020, 06:03 AM
the 2006 Pleasure Way Lexor seats do indeed us the stock GM foam under the PW custom coverings
disassembled the pass seat to plan out my fix
05-21-2020, 07:00 PM
I know there is useless info in this thread, these are the things I've run into and may help another...by spreading it out the info may be found more easily by search
PleasureWay seat swivel
while refurbing the seat;
( BTW the 4 x seat back bolts ( 13mm head) were all slightly backed out- I'll use a thread locker)
took apart, cleaned and lubed the seat swivel
the old lube was dry and black and gummy
pull cotter pin ( gotta nother?) and remove castle nut
the whole plate pulls straight up, there are 2 large washers/spacers on the top
set aside
below you will see the ball bearings captured in a plate- mine had some ok lube underneath and to make easier- I left this in place
clean up old lube/dirt/residue
my lube of choice for this is the "super lube" in grey tube with teflon- it does a good job of staying in place. another good choice is plumbers grease as it has a high melting point and stays put. or hi-temp bearing grease
added to top of bearings and plate
replace the seat mount holding lever in "release" position
( check spring is in good shape on lever, check lever bolts are snug ( mine weren't) and lube the sliding tongue
the smaller spacer first, a little lube on each side
then larger spacer
replace nut...I went snug to point where seat was hard to rotate and mount appeared to not rock/wiggle..but I'll have to recheck with seat in place and person in it
replace cotter pin
the entire mechanism rotates clean and smooth, the release lever pulls and returns with surety
mike
05-21-2020, 11:12 PM
Let us know how you like the new foam compared to the original.
05-21-2020, 11:24 PM
will do- amazon reviews are mostly positive- slight fear they will be too hard. Cushions will be here Tuesday
The driver seat cushion is about collapsed so a hand full of sticks and leaves would be improvement
in the install video they guys make mention that usually the outside edge breaks down from tradesmen sliding in and out of the seat all day.
for me it was the inside edge as I often enter the seat from inside the van
feels good to get under there and clean up the dirt/dust/grime, lube the swivel and slides etc
mike
05-23-2020, 01:23 AM
new seat pads arrived today- days earlier than expected
I already removed the seats to shampoo the coverings
using the seat guys youtube for a guide it took about an hour to get the base fron the back, new seat pads in place and the seats back together by myself
the Pleasure Way uses a zipper at the rear corners of each seat bottom - these were a bear to get back together
My Spouse came home at the right time and we got these zips done up with 4 hands
I maybe should have just trimmed back the foam on the "ears" a bit
mounted the seats in the van and the initial impression is that I am sitting up an inch and a half- much firmer than worn out seats and firmer I think than stock brand new.
mike
05-23-2020, 06:42 PM
Great information. I don't know how your RV compares to a 97PW. My swivel function was virtually zero on both seats when I got it from my inlaws. I don't think they ever swiveled those seats and the grease had really dried out. I did do some work but the driver's side is still very stiff. So I was especially interested in your discussion on the swivel plates. Thanks.
05-23-2020, 06:48 PM
they now swivel with one hand- it's amazing
mike
08-10-2020, 11:15 PM
update swivel do-over today.
when I had cleaned and lubed the bearings, I had indexed the nut and returned to same position and put the cotter pin in place before re-mounting the seat to the swivel base.
All has seemed well but the other evening the seat shifted on the swivel while driving. I pulled over and re"latched" it and then tested and all was fine until I leaned way back in the seat and it came free again.
This morning I pulled the cotter and tightened the nut then tested...tightened again ( castellated nut for the cotter) and all good.
I'd done same indexing of the pass side and testing it is fine...
When I did this job, I didnt think to really test the seats and assumed I'd be good- ooops
New seat cushions are awesome!
08-11-2020, 01:58 AM
Nice job, Mike!
Thread Tools |
Display Modes |
Linear Mode
