Old 06-20-2018, 12:26 AM   #1
bigfelipe's Avatar
Default Propane level doesn't work
I have a 2006 Roadtrek SS Agile and my propane level doesn't seem to be working. Any insight?
bigfelipe is offline   Reply With Quote
Old 06-20-2018, 02:10 AM   #2
Which level?
The one on the tank?
or the one at the panel?
It is expensive to replace the float sensor.
Most don't do well even in the best of times
Old 06-20-2018, 02:13 AM   #3
bigfelipe's Avatar
Which level?
Panel. Reads full. Gen died like it's empty.
Old 06-20-2018, 02:26 AM   #4
eric1514's Avatar
Crawl under the van and read the gauge on the tank. See if it also reads empty.
Old 06-20-2018, 04:21 AM   #5
bigfelipe's Avatar
I'll check it out in the morning. Never been under the tank before. Didn't know there was another gauge.
Old 06-20-2018, 04:28 AM   #6
Knit's Avatar
You don’t have to crawl under. It’s at the side of the van.
Knit is offline   Reply With Quote
Old 06-20-2018, 04:35 AM   #7
Knit's Avatar
The lpg tank is to the right of the driver door. There is a guage there.
Old 06-20-2018, 12:10 PM   #8
Most likely a loose wire (or a crossed wire, or a short wire).
Old 06-20-2018, 01:32 PM   #9
bigfelipe's Avatar
OK. So I crawled under the van this morning. There is no gauge anywhere I can see. Not on the side of the van, not inside the panel with the filler connection, not on the tank. I tapped on the tank. It sounds empty. I looked over the 2-wire connection I assume is the level sending unit. It looks to be ok. Nothing frayed or shorted looking.
Did I miss something?
Old 06-20-2018, 01:47 PM   #10
OK. So I crawled under the van this morning. . . .
Check the wire connection at the panel.
Do you have a multi-meter?
You can check for continuity and signal.
Old 06-20-2018, 01:50 PM   #11
You should have a gauge like this
File Type: jpg 14523273_1305337092831675_6357910096463650670_n.jpg (52.2 KB, 11 views)
Old 06-20-2018, 03:05 PM   #12
bigfelipe's Avatar
nope. not on my rig...
EDIT: AH HA! You are correct sir! Mine is a bit smaller around. The gauge plastic was worn to the point I couldn't tell it was transparent. I had to look at it twice to tell it was a gauge. I cleaned it up with some rubbing compound and I can read it now! Thanks.
Old 06-20-2018, 03:09 PM   #13
bigfelipe's Avatar
Have a bigger issue now. Gauges will have to wait. I got it refilled. Now the generator won't stay running... Fires right up, idles for a bit then cuts out. I checked the oil and it was low so I topped it off thinking it could be a low-oil shut off. Still the same. It will run for a bit but won't rev up and handle a load. I'm supposed to be on the road to FL in an hour... This is really crappy timing...
Old 06-20-2018, 03:13 PM   #14
When was the last time you use the gen?
How often do you use the gen?
Old 06-20-2018, 03:14 PM   #15
Search for Red Rover Onan trouble shooting guide.
Old 06-20-2018, 03:24 PM   #16
bigfelipe's Avatar
Last night when I ran out of propane. I use the gen regularly to exercise it. I run it under load for at least a half hour every week. It's not had any issues until now. Of course this was my 1st time running it out of propane and refilling the propane... Now that I have a gauge to go by I'll not let that happen again.
Old 06-20-2018, 03:29 PM   #17
bigfelipe's Avatar
I read it. It lists a bunch about gas but doesn't mention propane.
Old 06-20-2018, 03:39 PM   #18
Boxster1971's Avatar
If you ran out of propane that might be what caused problems. Try using some other LP appliances to get the flow to all parts of the system.
- - Mike
Old 06-20-2018, 03:51 PM   #19
bigfelipe's Avatar
- - Mike
All other appliances are working and the gen runs but not well. I'm wondering if running out of LP messed something up?
Old 06-20-2018, 06:52 PM   #20
The problem is a simple one.
Your propane regulator has a built-in anti-leak shut-off valve.
If the regulator detects an abnormally high-rate of gas flow, it will shut down the regulator.
This often happens when people run out of propane and drained the hose. When you refilled the propane and turn on the valve, the gas will rush to pressurize the hose, and the detector would mistaken it as a leak and shut down the valve.
What you have to do is to shut off the valve at the tank. Wait a bit for the regulator to reset itself. Then turn on the valve at the tank S-L-O-W-L-Y, so that the gas does not rush out to trigger the anti-leak shut-off valve.
Good luck.
