Old 08-03-2019, 05:29 PM   #1
Default remove air conditioner from 2008 roadtrek 190
I need to change the Dometic 3311563000 Run Start Capacitor
and looks like i would need to remove air or slide back
any info would be appreciated
pirtle is offline   Reply With Quote
Old 08-03-2019, 06:09 PM   #2
Welcome to the forum pirtle!
Plenty of members here with the 190 P model like yours. I'm sure they will be along to advise your shortly.
Is your a/c currently not working, or are you are just trying to ease the start amperage for your generator?
Old 08-03-2019, 06:13 PM   #3
Four screws at the aft bottom is all that is holding it. Wire nuts attach the AC line and a multi pin connector for the 12 volt control lines.
Takes two people and maybe two ladders to take it to the ground. While you are at it install an Easystart.
Old 08-03-2019, 06:39 PM   #4
Default easy start
My fan does not run,did not know about easy start
What is it and will it work on my model 41002.511
I am hoping to just slide out far enough to acess capacitor
Old 08-03-2019, 10:40 PM   #5
Plan on removing it completely.
https://www.globalyachtsupply.com/mi...BoCgsIQAvD_BwE
Old 08-04-2019, 12:08 PM   #6
sorry to hear that but will do thanks for all the replys
jim
Old 08-11-2019, 05:34 PM   #7
check YouTube..
Nicholas is offline   Reply With Quote
Old 08-11-2019, 11:26 PM   #8
I wanted to repair my AC on my RT too, but it is not reasonable. The difficult part is the unit must be removed to repair that. The new AC unit will only cost about $130. I removed mine and replaced it, then had a failure less than a year later. Nobody want to do that twice in one year!
Roadie is offline   Reply With Quote
Old 08-12-2019, 06:31 PM   #9
Default ytube
Nothing there on my unit
Old 08-15-2019, 08:15 PM   #10
Default install
holland motor homes installed the capacitor
Yes had to take it to the ground then reinstall 3 hours labor at $134 per hour
works great now
Old 05-05-2020, 02:23 AM   #11
Our thermostat in Popular 190 2012 (Dometic) is acting up. When it gets warm, doesn't kick in AC. If I push temp down it will. Does anyone know where to find replacement...have an URL for Dometic parts?
tomiverson is offline   Reply With Quote
Old 05-05-2020, 02:32 AM   #12
Here is one:
https://www.adventurerv.net/dometic-...waAnD-EALw_wcB
I also have one around the house here somewhere.
Personally I would (did) replace the A/C with a new one with a digital thermostat. Gonna cost about $1200 or so.
Old 05-05-2020, 03:07 AM   #13
Thanks! My daughter is taking a 2 day trip and will check it...maybe my imagination. But the info is really appreciated, as she may do a 2 month trip soon.
Old 05-05-2020, 04:30 AM   #14
My thermostat had a 10 degree difference between switch off and switch on (called hysteresis). A new one may be no better. A digital one claims 1 degree and I think that is correct. We haven’t come across a way to put a digital thermostat on the old A/C.
Old 05-05-2020, 11:35 AM   #15
Mine was "acting up" too. It turned out to be corrosion, New Orleans humidity.
I simply used some carb spray cleaner as I did not have any electrical spray to use at the time. Removed the cover and sprayed liberally moving the the thermostat knob up and down quickly. A few times, dried out, and Bingo!
I have needed to do it every few years.
Old 10-09-2020, 07:14 PM   #16
I removed the dometic on my 2002 190 Popular since it failed again...second time....getting it out was only work because I did not know how mine was mounted in. The answer was not with much so once I figured out how to remove the rest was easy. If you need my specifics let me know.
2002Roadtrek190 is offline   Reply With Quote
Old 10-25-2020, 09:56 PM   #17
The same thing happened to me. The recent failure prompted calls to RV repair shops with prices of $1500 plus and amulti month wait for parts so I took out the dometic heat pump air conditioner and put in an Emerson window air conditioner. $200 plus a days work. I think the whole system is much simpler now.
Thread Tools
Display Modes
