Old 11-28-2021, 02:32 PM   #1
Default Roadtrek Agile thermostat cover
Hi, i am looking for a cover for. a Roadtrek SS Agile 2007 or 2008. This is on the left side of the RV above the window. I am attaching a picture.
Thank you for your help.
File Type: jpg A8345059-035F-4B57-B623-17A6736D94EC.jpg (329.9 KB, 12 views)
trek08 is offline   Reply With Quote
Old 11-28-2021, 02:55 PM   #2
Might be easier to just replace the thermostat.
mikeehlert is offline   Reply With Quote
Old 11-29-2021, 05:53 PM   #3
I have replaced mine with this one:
https://www.amazon.com/Emerson-1E78-...2%2CB003ET7FRA
The inside temp is much more constant than a mechanical one.
pomerlo is offline   Reply With Quote
Old 11-29-2021, 07:13 PM   #4
I ordered one, thank you all for the advice
Old 12-16-2021, 12:44 AM   #5
Hi, is there a particular way to install this ? the old one had red and white wire, read the direction for the new but cant really tell. Picture of the old one. I can het the pic of the new one as is installed. Any input appreciated.
File Type: jpg 3CC01527-60E4-4B50-92FA-C3B628262327.jpg (129.8 KB, 4 views)
Old 12-16-2021, 02:40 AM   #6
Normally in your Roadtrek you only have 2 wires that goes to your heater. You mention a red and a white. The thermostat simply connect those 2 wires together in order to start the heater. It act like a single pole On-Off switch.
Your new thermostat has a diagram showing the terminal that must be used when you have 2 wires. (At terminal marked W and RH it doesn't matter where you put the red and the white as long as you use the W and RH. Leave the jumper as it is between the RC and RH terminals. The transformer on the diagram is not there and not needed.
see pic below
Good luck
Old 12-29-2021, 12:29 AM   #7
Installed and all mounted. Thank you for all the help😀
File Type: jpg 98E4EE9F-143D-4328-8987-3AC715104025.jpg (240.0 KB, 1 views)
Old 12-29-2021, 03:03 PM   #8
nice job... Glad to help !
