Old 11-14-2021, 09:39 PM   #1
Default Sprinter van. CRL Side window leaking...
I assume it is a Cr Lawrence window.
2012 Roadtrek RS Adventurous.
Leak appears to be between mounting clamp and window. I see no signs of water directly below clamp, and no signs of water at bottom of tilt out window. When I removed a screw for the window trim (placed in the clamp) some water came out. Appears to happen when the van is parked with the front slightly down.
Are there any resources/guides on removal/resealing these windows? Is there a place to get a new gasket/shim?
Or, can I just seal the screws and seam between the clamp and window??
I am thinking I need to remove, and get the proper stuff from CRL
Any ideas would be helpful...
See PICS.
LarryNH914 is offline   Reply With Quote
Old 11-25-2021, 04:02 PM   #2
Hello, on my 2008 RS I had the same problem same window. I have solved it over the years by using Captain Tolleys leak sealer. I applied it on the top outside of the window. You don’t need much it is very viscous, so try not to let it run on your paint. Check it out.
Titequarters is offline   Reply With Quote
Old 11-25-2021, 05:29 PM   #3
I second Titequarters on the Captain Tolleys. It worked very well for me on my boat.
Blue Note is offline   Reply With Quote
