Old 06-01-2023, 08:33 PM   #1
Default Two Stage Propane Regulator leaking...again
I have gone through two of these this camping season already. I replaced with the same model that was installed when I purchased this vehicle (2012 Pleasure Way Traverse) in January. The regulator is the Camco 59313 Vertical Two Stage Propane Regulator. I am not sure why this keeps going bad. Is there a different / better regulator to use?
BarryW is offline   Reply With Quote
Old 06-01-2023, 08:42 PM   #2
Marshall Excelsior. It has slightly different mounting hole locations.
Old 06-02-2023, 04:32 PM   #3
I second Marshall Excelsior. Replaced leaky one with a ME 2+ years ago and no problems.
Old 06-08-2023, 10:19 PM   #4
I third the Marshall. The regulator is a huge issue with the newer PWs. I thought your year had the Marshall, but I guess not. I carry a spare, but my 14 year old is still working fine.
Old 06-10-2023, 01:42 PM   #5
I had the hose fittings leak and the dual stage pressure regulator wasn't regulating. so I got rid of the quick connect and just went with a single pressure regulator. seems like the hoses and plumbing on the roadtrek is overly complicated. not sure what the pleasure way set up looks like, but two pressure regulators leaking sounds suspicious. I'd absolutely go with a different brand, if it's truly the regulator is leaking. but maybe you should re-check all your fittings and hoses while you're under there.
2007 TurdWrek 190 popular
Todd
tlillard23 is offline   Reply With Quote
camco 59313, propane regulator, traverse
