08-28-2017, 08:28 AM
#501
I have Stow-Away 2 so based on my personal experience and seeing the video below I would likely choose the Rola System because:
1. It seems that Rola seems to swings farther away than Stow-Away so the rear/right Sprinter door could be fully opened, needs verification.
2. The latching mechanism on the Stow-Away is prone to heat warping, needs some gymnastics to function normally.
3. The Rola box can be removed easily, Stow-Away not.
4. The Rola can be stored easier in the garage because of easy separation of the box from the hitch. The box could be left at the campsite with some security.
5. Rola is 1 CF larger.
09-20-2017, 10:07 PM
#502
Partially inspired by James@FitRV, here's my version of the back wall storage "cabinet" on my G.
Exploratory hole.
Cut out.
Finished and partially filled.
"Il Travato Rosso"
2015 Travato 59g
09-21-2017, 02:14 PM
#503
Oh, that's really clever! I didn't realize there was that much of an air gap between the back wall and bathroom.
2018 Coachmen Crossfit/Beyond
09-21-2017, 03:08 PM
#504
That is nice!
10-13-2017, 05:58 PM
#505
Originally Posted by Saldar
I think solar panels may interfere with use of the moveable ladder. The ladder, when detached and moved, hangs on the rack. It looks like the 80W panels, so near the edge, would interfere. In the panel/obstruction/shadow jigsaw, there is now a ladder access piece to fit in.
I'm glad to learn rack mounted panels can be more efficient. Maybe we will get something more out of the ladder/rack beyond just carrying our our chairs!
I just wanted to report that two 100W Zamp panels fit on the WBO rack on the back of a 2017.5 Travato 59K. They "just" fit when we finally got them up there. They clear the protrusions (2 vents, bath fan and Zamp connection box) on the roof fine. The ladder isn't a problem. The WBO provided Zamp panel is next to a 100W Zamp panel having the new mounting channel. The panels are about 10 inches behind the AC unit. Because they are raised on the rack, only about 6 inches of the monster AC towers above them.
This configuration would get shade from AC during late or early hours, if at all. Alternatively two Zamp 80 watt panels can be mounted on each side of the AC. Even though these panels add more wattage I think they would net less due to shading since they fit so directly adjacent to the AC shroud.
10-13-2017, 07:14 PM
#506
Hi Saldar, would it be possible to get a picture of the roof with the two zamp panels? Also, if you have the new style Winnebago made bicycle rack, do you see any possibility of relocating it to a higher position on the door to allow room to use it and a reciever mounted cargo box at the same time? Thanks.
10-14-2017, 12:01 PM
#507
Sorry Saldar, I re-read your earlier posts, so please disregard my bike rack question.
I had a closer look at a few pictures I took at the dealer. The Winnebago Bike Rack looks like it would be difficult to remount higher on the rear door. Also, it looks like the mounting points for the rack would be in the way if you went to install a Fiamma Bike Rack later.
10-14-2017, 02:14 PM
#508
Originally Posted by fruch
Hi Saldar, would it be possible to get a picture of the roof with the two zamp panels? Thanks.
Here are the solar panels on our 2017.5 Travato 59K on the WBO rack. They are side-by-side with the long dimensions of the two 100W Zamp panels parallel to the long dimension of the van. There is basically only one way to hang them.
10-14-2017, 02:40 PM
#509
You have one mono and one poly panel.
10-15-2017, 11:47 AM
#510
Thanks for the pictures Saldar!
10-15-2017, 11:49 AM
#511
Saldar, Thank you for the pictures!
10-15-2017, 07:28 PM
#512
According to the original Zamp stickers on the backs, each panel is mono. They have slightly different specs however. The black one came with the WBO package.
10-15-2017, 08:20 PM
#513
Monocrystalline cells are cut from silicon round ingots and have distinct contour. Your passenger side panel could be polycrystalline or even a thin film, difficult to see it on your photo, it is very unlikely that is monocrystalline. https://en.wikipedia.org/wiki/Monocrystalline_silicon
10-15-2017, 11:15 PM
#514
This is the new expansion panel from Zamp (the same one the poster used and the same one our neighbour has). The Zamp link and the back of the panel both say mono. Just trying to understand why you(s) don’t think it’s a mono panel???
https://www.zampsolar.com/rv-solar-panel-kits/
10-15-2017, 11:16 PM
#515
The obliqueness of my photo makes one panel look flat black. Zamp has updated the cell shape and possibly the reflectivity of the glass. Here are ads for the new and old style panels. Both touted as mono, and I think accurately. I hope they both are because these USA panels are quite expensive -- but plug and play if you can get them up there.
10-16-2017, 01:34 PM
#517
I had no idea this solar panel thing was so complicated. After reading these comments, I have a few questions about solar panels and the Travato. As I understand it, a Travato equipped with a solar package comes with a 100W Panel, a controller, a plug in terminal connector on the roof that allows for two more solar panels to be connected to the system, and, a plug in terminal on the passenger side of the Travato to allow for an additional solar panel to be connected to the system. Do all panels connected to the system have to be the same size, type of construction, and have the same output as the original 100W panel that comes with the Travato? Is there a risk of damage to the system if you mix size and type of panels? At what point are you overloading the system with too many panels? Thanks.
10-16-2017, 01:52 PM
#518
YOu can connect panels in two ways:
1. in parallel
2. in series
When in parallel, the panels can be of different wattages, but they should be the same voltage.
When in series, the panels should be the same wattage.
ps. the connector box on the roof allows for parallel connection. Same as the socket on the side of the RV.
10-16-2017, 02:34 PM
#519
Last year we came very close to jumping on a Travato 59K. We visited the dealer 3-4 times, over a period of 6 months, and kept coming back to that model. The sticking point, however, was that the driver seat didn't recline sufficiently for my back issues, and since then the prices have been upped, but we still like the layout with all the windows.
10-16-2017, 02:44 PM
#520
……………………… Is there a risk of damage to the system if you mix size and type of panels? At what point are you overloading the system with too many panels? Thanks.
This risk doesn’t exist with an MPPT or a PWM charge controller programmed correctly.
Thread Tools |
Display Modes |
Linear Mode
