Old 01-08-2007, 03:43 AM   #1
Default Shurflo 3200-200 macerator pump
Shurflo 3200-200 listed in newer Roadtrek manuals
OEM# 3200-200
Aftermarket # 3200-001
Description: Designed specifically for sanitation waste evacuation
Voltage: 12VDC
Dimensions: 10.8" x 4.5" x 3.8"
[274mm] x [114mm] x [97mm]
Flow Rate: 10.0 GPM [37.9 LPM]
Amps: 15
Ambient Temp. 33- 140 F [0.5 - 60 C]
Inlet: 1-1/2" NPT-Male
Outlet: 1" Barb
Product Data Sheet Right click, save as....
Installation, Operation & Repair Manual Right click, save as....
Old 11-25-2020, 09:23 PM   #2
I can't find anything on these pumps and replacing the sewer hose on this. I have a winnebago ERA 70 X that comes with a shurflo 3200 macerator pump. Need to replace the hose which has cracked. would like to replace with a good hose that fits in the water service center that comes with this RV. Thanks. Any Ideas?
IrishCalexico is offline   Reply With Quote
Old 11-29-2020, 11:51 PM   #3
Sorry, no ideas to help you but just in case you or any other readers ever need....
I needed emergency replacement Shurflo pump this summer when far away from RV suppliers. I did have a marine supplier nearby, they had similar Jabsco pump on hand. Turns out to be almost exact replacement - all fittings and mounts were exact match and fit in perfectly. Only difference was electric wires came out oc unit in a different spot but were long enough to attach without adding extension.
Not any cheaper than Shurflo but in an emergency it worked well.
Later, took the Shurflo apart to fond impeller faulty so replacing it alone would have fixed my problem but I’m sure getting that part would not be fast or easy either.
Aggie is offline   Reply With Quote
Old 11-30-2020, 02:31 PM   #4
Welcome to the forum Aggie!
Very helpful first post.
Old 01-20-2021, 01:31 AM   #5
Shurflo 3200 stopped working- turned screw on end and freed up impellers however stopped working again. Bad unit or something else’s?
SmokeyFoster is offline   Reply With Quote
Old 01-20-2021, 02:43 AM   #6
By “stopped working again” do you mean it runs but doesn’t pump or doesn’t run at all ? If it runs but doesn’t pump, its probably just worn out impeller. If it doesn’t run at all it’s either not getting power due to blown fuse, wiring fault or motor is faulty.
