Old 01-09-2021, 08:34 PM   #1
Default Hidden leaks/sour smells - How far to look?
Has anyone with an older Roadtrek experienced a leak from the fantastic fan that wasn't obvious and accumulated behind the vinyl ceiling? Just curious. Or has anybody else had an unexplained sour odor that turned out to be a hidden leak from - say - the kitchen window (ours is fixed and you can't see if there is a leak without doing a lot of tear out)? I'm trying to figure out how much tear-out to do to hunt down a sour odor that I know isn't the grey tank or the black tank. I'm not finding any wet spots anywhere that I can see. Who knows - maybe it's the occasional spicy stuff we like to cook in the evening that's finally built up to critical levels. Any deodorizing tips are much appreciated, especially wood treatments. Thanks Forum!!
Average_alice is offline   Reply With Quote
Old 01-10-2021, 03:50 PM   #2
after being caught "tornado adjacent" and water POURING in the top of our pleasure way....
I scraped/ removed everything and resealed.
the antenna crank may have been an issue.
easiest was to remove vent/fan and standing on stool in van was able to reach almost every one of the penetrations -preferable to standing on ladder outside and constantly reposition myself and ladder.
2 day project
also resealed gap at top to van, I found some areas there which were weak
mike
Old 01-10-2021, 04:18 PM   #3
Yes, periodically checking your roof for leaks is a very good idea.
In Sprinters, roof leaks often end up flowing onto the front overhead lighting console, just over the windshield. This is NOT just a light--it contains a $400 electronics module which very commonly fails due to repeated moisture exposure. Happened to me recently as the result of a leak in the TV antenna penetration.
The best thing to do is to periodically get out the ladder and a water hose and check each penetration for leaks. Under high pressure, they are usually quite obvious.
BTW: another possible source of a strange smell is a dead rodent.
Old 01-11-2021, 12:10 AM   #4
You have to service the caulking for all of the roof penetrations every couple years. If your Roadtrek has the roof windows with the rubber frames around them those are a nightmare.
The servicing is basically pulling it all off from the roof vent, removing the screws, recaulking the screws, and recaulking the vent.
I like to use LePage Quad calking in Canada but I'm not sure what is available in the US.
https://www.lepage.ca/en/lepage-prod...ngsealant.html
It is nice and stretchy plus it adheres well. Do not use silicone as it's pretty much junk.
There is also RV specific sealants that you can pour over the vent seams but I've never used them.
Stevemo is offline   Reply With Quote
Old 01-15-2021, 07:46 AM   #5
There are extremely accurate moisture sensors that the check moisture without using a puncture probe. They were to be quite expensive to buy but RV dealers in Europe and New Zealand have them. I have never checked in North America.
Redfish is offline   Reply With Quote
