Old 01-13-2019, 06:44 PM   #21
Originally Posted by israndy View Post
I used to have a Gulfstream Class B Sprinter RV, that had an on-demand water heater, cannot remember the manufacturer. The only "warm" shower I ever took was in an RV park in summer. The temp of the water in the tank has a BIG impact. Actually thought about putting a solar heater on the roof and cycling the tank water thru. That would also keep the cabin warm at night with that big thermal mass. The other issue was the rate of flow. If it was too low the heater kept turning off and back on, if it was too high the heater didn't have enough time to heat the water. Best I ever measured from it was 92°
There is a product on the market now that uses an Omic Array to heat the water, I like to think of it like microwaving the water to heat it more efficiently than a resistive coil. Check out HeatWorks, the Model 1 that they used to make may be perfect for an RV. Still, if you want a realistic shower on-demand you may wanna look into putting a second power plug on the outside of the RV for 220V so you can run a dedicated wire from the park pedestal 50 amp plug to the water heater. Use the 30 amp plug for everything else. Most places offer both.
-Randy
According to the chart that I posted above one would be limited to the ECO 8. Not too much flow rating there at the cooler temps. The GPM and temp rise is assumming out flow at 105*F. This would be very problematic up north and in the mountains.
Electric coil with a storage tank seems to be the way to go.
Old 01-14-2019, 01:02 AM   #22
NFRicaS's Avatar
Originally Posted by Boxster1971 View Post
That is a very nice water heater. I had to dig a bit to find it as the basic Bosch Tronic 3000 is a tankless water heater. You are using a Bosch Tronic 3000T Mini-Tank Series ES4.
https://www.homedepot.com/p/Bosch-4-...ES-4/206393135
About half the cost of a typical RV water heater.
Thanks for info..do you think since it’s only 4 gal., it could be heated up w/ 30 amp connection? It looks like it will fit in the space where my current hot water tank is. I don’t have to have “on demand”..just hot water w/o using propane..
NFRicaS is offline   Reply With Quote
Old 01-14-2019, 05:41 AM   #23
Originally Posted by NFRicaS View Post
I never have liked/used the propane in my RV...thought I read somewhere about a way to replace the tank with an (on-demand?) electric hot water heater..I have measured the space, have a picture of current hot water tank (can’t figure out how to attach .would love to just take out/off the propane tank..Welcoming ideas..thoughts..
In my virtual build-it-yourself van, I looked into the feasibility of using electrically heated water. You can buy an ordinary small 120v under-counter heater and swap out the high wattage 120 volt element for a low wattage 12 volt element. Here are links to those items.
Home Depot Rheem 2.5 gallon electric water heater (1440 watts) $180:
https://www.homedepot.com/p/Rheem-Pe...14U0/204318371
Missouri 12V DC adjustable water heater element (200 watts) $80:
6 Inch Adjustable DC Submersible Water Heater Element - Missouri Wind
200 watts is enough to heat up 2.5 gallons in under 3 hours (see math below). By switching out the 120v heating element, you won't need to have your inverter running to get hot water. Besides, the 120v elements draw too much power. They seemed designed to provide almost instant hot water.
The standard alternator on a Promaster van puts out 180 amps, which is over 2000 watts. If you upgrade to lithium batteries in your coach you should be able to keep that water plenty hot. Just don't take any baths, or expect to do dishes and take a shower.
Doing the math: Assuming you heat water from 50 degrees to 130 degrees, that is an 80 degree rise. Each gallon of water requires 8.4 BTU to raise the temperature 1 degree F. So to raise 2.5 gallons 80 degrees requires about 1700 BTU. Since each watt-hour is equivalent to 3.4 BTU, you will need 500 watt-hours to heat up a 2.5 gallon tank 80 degrees. A 200 watt heating element should do this in about 3 hours (assuming some losses).
A 100 Amp-Hour lithium battery holds 1200 watt-hours, but figuring only 50% discharge that leaves about 600 watt-hours. That is enough to heat up a 2.5 gallon water tank. Perhaps in the distant future we could heat a van with batteries alone, but for now a propane furnace is required. You must still carry propane for heating if you are not connected to shore power. [Note: a Winnebago Revel has a diesel furnace and doesn't use propane.]
There are 12 volt marine water heaters, but those require high wattage, are rather expensive, and meet strict regulations. For some reason RVs are relatively unregulated, which allows us to build our own without oversight. Hope this posting helps.
{DougB, Retired Techy}
dougbaty is offline   Reply With Quote
Old 01-15-2019, 02:33 PM   #24
NFRicaS's Avatar
Thanks everyone for all responses, I will need to find someone who understands all that has been discussed and help me make a plan..I am currently in Austin, TX until May, so if anyone has someone in that area who might help w/ a plan, feel free to message me..
Old 01-16-2019, 05:10 PM   #25
Kab449's Avatar
Originally Posted by magicbus View Post
If you have space for a Truma Combi you might look at that as it also provides nice hot air heat eliminating a separate furnace. The hot water tank is just over 2.5 gallons.
I have this in my Galleria Class B. Hot water on demand and it also doubles as a furnace that heats the air. Works great and uses Electric, Propane, or a combination of both. You have the flexibility to operate the Combi most efficiently depending on your circumstance. At a rest stop on propane, or in a campground hooked up to electricity. Not sure why you would eliminate the use of propane if you already have it.
Web search Truma Combi.
Keith & Brenda
Central PA
Marley the Maltese
2018 Coachmen Galleria 24Q
Kab449 is offline   Reply With Quote
Old 02-08-2019, 04:05 PM   #26
I installed a HOTROD 110v heating element that takes the place of the anode rod. I could not stand hearing the LPG heat going off every 1/2 hour when camping in the cold. This works great!
Classic Vans is offline   Reply With Quote
Old 11-02-2019, 03:05 AM   #27
NFRicaS's Avatar
HELP!! Can’t figure out hoe=w to start a new thread/post, whatever...I am stuck in Lumberton, NC, with a 2 day issue w/ my Pleasure Way Lexor on Chevy 3500 chassis..driving on hwy, battery light came on, went to auto parts, they tested, said Alternator was bad..got an alternator, guy came out, put it in, same issue w/ battery light..got another alternator, was tested, put it in..light on/off, etc. I went to a CG for the night, same issue popped up in the a.m., Alternator not charging battery..went back to mechanic, he worked on it, fuses replaced, etc, finally he looked at starter wire, said it was corroded, cleaned it, thought I was good..get 230 miles away, same problem..Chevy Dealer says it’s the Alternator!! NO!! Does anyone have any ideas? Wires leading to Imverter and Battery test ok, but is something causing New Alternators to go bad or is Chevy Place wrong? Please help...I was supposed to be in Florida by tomorrow or so!! Any ideas??
RS
2004 Pleasure Way “Completely Redone” -
All University of Texas Decor!! “Hook ‘EM” ~0~
Old 11-02-2019, 11:44 AM   #28
The first question has to be if the charging is really bad or not. What does the dash voltmeter say? What does a voltmeter on the battery say when engine off and when engine is on.
You could really have a charging issue, or just an indicator issue.
Does the van have and isolator installed? If so, they can also cause these kinds of issues.
To start a thread, go to the forum front page, chose a subforum from the list of them, click the forum and you get a list of topics. Just above the list of topics is a "new thread" button to click and start your new topic.
Old 11-06-2019, 11:19 AM   #29
NFRicaS's Avatar
Thanks for your reply...was stuck for two days, and then got it to an Auto Electric place. They didn’t have time to work on it all day (they were FULL of cars) but finally decided that the fuse (ignition #22) keeps blowing due to cruise control..not sure why it went 230 miles before blowing (for the umpteenth time), but they seemed to think it wouldn’t blow fuse if didn’t use Cruise Control..of course that fuse controls alternator, brake lights, turn signals & Cruise Control...made it 490 miles to Florida, no CC, no problems..fingers crossed till I get back to Texas!!
RS
Thread Tools
Display Modes
