-   -   EFOY Fuel Cells (https://www.classbforum.com/forums/f5/efoy-fuel-cells-2239.html)
markopolo 09-21-2012 11:29 PM
EFOY Fuel Cells
2 Attachment(s)
A bit of info about the Efoy Fuel Cell
markopolo 09-22-2012 12:02 AM
Re: EFOY Fuel Cells
Video of the EFOY fuel cell
[youtube:1krox0y7]wHcRXKDpI4A[/youtube:1krox0y7]
The reporter said $65 for a methanol cartridge and between $4,000 and $6,000 for the EFOY unit
markopolo 09-22-2012 03:55 PM
Re: EFOY Fuel Cells
1 Attachment(s)
The 10L methanol "cartridge" is not small and it weighs 39 lbs.
You need space for the primary cartridge but where / how would you store a spare one in a Class B?
Davydd 09-22-2012 04:55 PM
Re: EFOY Fuel Cells
Maybe "basement" storage since you would not have an Onan generator underneath.
AmCruiser 09-23-2012 11:03 AM
Re: EFOY Fuel Cells
Any idea how long a cartridge would last assuming average "B" power consumption?
markopolo 09-24-2012 12:39 PM
Re: EFOY Fuel Cells
That's a great question.
I wonder what average "B" power consumption is..........
Pump, lights, fan, furnace, newer fridges, propane detector ..........
My older manual control fridge doesn't need DC to run. The wire is not even connected.
AmCruiser 09-26-2012 10:17 AM
Re: EFOY Fuel Cells
I went to the Protonix link in Davydd's 9/22 post in the New models and option string. Their propane P125B fuel cell is designed for easy retofit into an existing RV's propane and electrical system and operation is fully automatic to keep the batteries charged similar to EFOY. The brochure says it will operate 164 hours on a 20 lb tank.
On units that have propane on board, that seems to make more sense than EFOY. I suspect the availabilty of replacement EFOY methanol containers is limited meaning you need to bring what you need with you. Given their size and weight, having them shipped to your home would be quite pricey, so tht pretty much limits you to getting them thru an RV dealership that carries them which potentially could require driving some distance to restock. I think the Protonix unit seems more practical for RV's as your not locked in to a proprietary fuel source.
