-   Winnebago Rialta and LeSharo (https://www.classbforum.com/forums/f52/)
-   -   Why is water coming out my hose fill for city hook up? (https://www.classbforum.com/forums/f52/why-is-water-coming-out-my-hose-fill-for-city-hook-up-5083.html)
herbert 04-04-2015 01:52 AM
Sinced i have unwinterized my rialta.. When I turn my pump on to use the water from the fresh water tank it starts pumping it out the city hose hook up.. Is this normal?? never had it do it before.. Thanks for any advise..
TXPigeon 04-04-2015 07:09 AM
There's a spring loaded plunger in the center of the water fill that sometimes gets tilted and doesn't close properly. You may be able to wiggle it with your finger and get it to seat. You could also try applying air or water pressure for a couple of seconds. If that doesn't work, you'll probably need to replace it.
Duane
herbert 04-05-2015 03:05 AM
Duane
Thank you Duane.. I will check it out..
herbert 04-09-2015 02:21 AM
Found it and fixed it.. thank you so much for the info Duane
