-   -   Round lamp over table - wiring (https://www.classbforum.com/forums/f5/round-lamp-over-table-wiring-791.html)
K1smm 03-26-2008 03:41 AM
If anyone knows how the wiring is routed to the over table round light, I would greatly appreciate that data. I measure no voltage coming to it and all the fuses in the converter are OK. I hate to go digging around that large crossmember.
What a great group!
Thanks
JA
markopolo 03-26-2008 12:24 PM
Is your Class B a Roadtrek? If so, try sending an email to service@roadtrek.com - enquiries should go through dealers but they've responded to my direct enquiries re: technical matters.
Have you been able to check the wiring going into the light fixture (before the switch)?
K1smm 04-06-2008 08:42 PM
Yes it is a Roadtrek. I will try the manufacturer. To clarify: I measure no voltage before the switch and I do not know the routing of the wires, hence the query.
Thanks
Jack
1994 190 P
Copyright ©2000 - 2022, vBulletin Solutions, Inc.
