-   Computers, Internet, Tech stuff (https://www.classbforum.com/forums/f26/)
-   -   RV Internet (https://www.classbforum.com/forums/f26/rv-internet-8728.html)
mrq3883 01-20-2019 06:03 PM
RV Internet
After upgrading the TV in our 05 Pleasure-Way Excel TS, I found that internet access was necessary to utilize the apps built in to the Vizio TV. I'm using a Verizon 4GLTE Home (Novatel T1114) router, which worked great for a local trip last week. Watched Netflix without interruption. I'm adding an omni-directional antenna to increase our range and help us keep signal for longer trips. Has anyone else tried this type of setup for internet access?
avanti 01-20-2019 07:50 PM
Here is a thread on this topic:
https://www.classbforum.com/forums/f5...html#post73350
If you REALLY want a good external antenna, you definitely want a setup that uses MiMo (described in the above thread). Vastly superior to any other approach. You would probably need a new modem, though.
mrq3883 01-23-2019 10:02 PM
Modem
Not so easy, as the modem is also the hotspot.
avanti 01-24-2019 06:06 PM
Very easy. There are several hotspots that support MiMo, including the AC791L that I mentioned in the linked thread.
David Pouliot 01-27-2019 06:37 PM
I have a Samsung phone with an unlimited plan . I replaced the tv with a Samsung TV. There is an app where you can mirror the screen ..I log on and watch unlimited Hulu, Netflix, and prime.
I also have a surface pro with 4g on an add on the account. I very rarely go without internet ..Binge watched yesterday in the rain for several hours
