-   -   Where does your charging come from survey (https://www.classbforum.com/forums/f23/where-does-your-charging-come-from-survey-9857.html)
booster 11-02-2019 01:52 PM
Buried in another, very contentious, thread on this forum is a question that I think would be interesting for many of us to better understand and for those contemplating charging system changes and upgrades to see from actual users.
The question is: What percent of your power comes from the various power sources available in our class b vans? The question is simple, but the answers are certainly not be precise because conditions camped in change all the time, for all of us. Just try to hit a median approximation of normal conditions and primarily based on when shore power is not commonly available. Be sure to give an estimate of your daily power use also, as that is a critical factor for people to know when they try to decide on a charging system.
For us in our 07 C190P Roadtrek, 440ah of AGM, engine generator, 300w solar, no generator, no air conditioning on batteries:
Our power use in normally in the 30-70ah per day
70-95% solar
5-30% engine generator
0% for generator as we don't have or need one
Shore power only needed of solar conditions so bad (very, very, rare) for a week that we need to do a full top off AGM batteries for life preservation. Shore power never needed for daily use power replacement. We have been known to get shore power to run air conditioning if it is 100*+, though.
Davydd 11-02-2019 03:04 PM
I can easily use over 160-200ah per day but it is a drop in the bucket when I have an 800ah lithium battery bank. I don't worry about electrical use with an all electric system coupled with diesel-fired heat and hot water. So cooking in a convection oven and induction cooktop and making several cups of coffee in a Keurig is routine. Having the inverter on all the time is standard for us since I'm constantly fidgeting using my 120V electrically powered articulating beds when stopped to adjust them for sitting up, lazy-boy fashion or zero-gravity positions or making a quick two mugs of coffee while stopping at a service station. Having the inverter always on takes about 3 amps per hour power. It's transparent with electrical use whether I am on shore power (seldom) or boondocking.
Driving up to about 45 minutes a day maximum replenishes my daily electrical use with a Delco second alternator rated at 330a but consistently gives me over 270-280a running for an hour. So I don't know if it drops in performance as I reach 100% charged by that time. There is some solar contribution with 420w panels but I have pretty much dismissed that and will not get solar again. And, no, I don't need to idle my engine with the second alternator. That's a false assumption by many of those who don't have second alternators. The capability is there and offered by Mercedes Benz to install it with idle adjustment capability and brackets but it is just a bells and whistle emergency situation which we never encounter. I have idled when staying more than 3 days in a non-electric campground without driving anywhere but that was just more of peace of mind as I have never come near depleting our batteries.
Air conditioning use? Almost never with our traveling habits. If I really needed it, I would seek a shore power campground. You can only get probably up to 10 hours with just about anyone's system and you typically stay about 16 hours minimum in an overnight stay. It doesn't compute. I can count the fingers on one hand where I desperately felt I needed air conditioning in a boondocking situation in 12 years and over 200,000 miles of travel.
Jon in AZ 11-02-2019 05:40 PM
100% charge from shore power at home before trip.
Partial recharge (~25%) from engine alternator during day trip away from camp.
Full recharge from engine alternator on drive home.
No solar or generator .
Lights, bed, awning, and recharging electronics only. Cooking and refrigeration on LP. No heat or A/C needed. 2@6V GC2 wet cell
Never went below 2/3 on the battery monitor.
This was our first trip (6 days) and we’ve got a lot to learn yet! Couldn’t figure out how to work the TV via the inverter so we played scrabble instead. Win-win.
SteveJ 11-02-2019 08:35 PM
I'll play.
2000 RT on a Chevy chassis.
Normal daily usage 15-20 AH/24 hours, significantly less on a one nighter when traveling. Cold weather will increase the AH. LP fridge.
Virtually all extended boondocking recharge is from 150 watts of portable solar. On two nighters I use the chassis alternator for recharge, not bothering with the solar
Battery is a Wally World Everstart Maxx. group 27 deep cycle maintenance free non AGM.
Plugged in at home to maintain 13.2 volts with a cigarette lighter jumper to the chassis battery.
GeorgeRa 11-03-2019 01:58 AM
This is a summary of our usage in 2013 Sprinter Camper Van.
Power sources: 300W PV panels, Engine alternator up to 25-30A, Shore charger 40A
Batteries: 230 Ah AGM
Main loads: Isotherm 85 fridge, Espar Airtronics D2 diesel space heater, Espar Hydronic D5/electric 750W Isotemp water heater, Origo 1100W electric/alcohol stove, 650W Microwave, LG Projector ~ 100W, NO AC.
3 scenarios based on different camping conditions:
1. Solar harvesting campsite – about 45 Ah/24 hours, batteries usually replenished by midday, no time limit.
2. Cloudy or shady campsite – up to 3 – 4 days pending ambient temperature and TV/computer use.
3. Cloudy or shady campsite with shore power – no time limit.
GallenH 11-03-2019 02:58 AM
1997 PW on Dodge 3500 chassis.
Batteries: 100AH Lifeline AGM
Solar: 100W Renogy suitcase
Needs: water pump, furnace fan, LED interior lights, vent fan.
So I'm pretty basic. We don't watch TV rather use an iPad pro loaded with movies, TV series etc. Cooking, water heater, furnace heat = LP
Generally we're on the move each day but when we're in Cibola, AZ we're on BLM land and don't move or idle. Typical is that we're down 20% in the morning and regain that power by noon or so. Remember AZ is usually full sun without a cloud in the sky.
Bottom line: When we're traveling the chassis alternator always charges us up to full. Solar is a benefit when we're stationary but that's rare. We are rarely in campgrounds that have shore power. However, our power demands are minimal.
rowiebowie 11-03-2019 12:30 PM
A little over 2 weeks into our first trip with the 200ah lithium upgrade and here's how I'd roughly describe our experience.
- Solar 0%.
- Engine charging while driving 25%.
- 30A plug in 75%.
We've boondocked 5 nights (in 1 night intervals) and plugged in 11 nights (oddly this is the reverse of our usual experiences but full service parks have been plentiful this trip).
When plugged in we leave with batteries in the 92-89% range in the morning since the batteries don't seem to want to automatically charge until down closer to 80%. But somewhere in the mid to upper 80% range, I can add a brief load (microwave) to trigger the charging to 100%. This morning at 91% the charger did not come one when the microwave (load) was used.
However when driving, if I have the switch on to activate the DC-DC charger, it will always charge (no matter what the battery level) until they are 100%. But I don't always allow the engine alternator to charge the coach lithium batteries since it sometimes won't charge enough at idle. Have to look into that when I get home.
For the most part, 200Ah of lithium's has erased my battery anxiety and could probabaly allow us to boondock for 3-4 nights if we were to conserve use by limiting the microwave.
papab 11-03-2019 03:54 PM
Our system: Promaster campervan. I just added e-bikes and upgraded the power so I have 2 systems shown below, old and new (which I haven't had much time on yet). 12V fridge and espar heater are the biggest loads.
Old: 210W solar, 150 ah, 12V aging/failing Lifeline AGM. no generator, 60 amp xantrex charger for shore power or while driving.
Typical about 25 ah DOD in the morning. That sulphated battery takes many hours in absorb to get to 100%. I typically stay in one place for several days and rarely have AC power, and never idle the engine to charge, so the power is mostly from the solar. Sometimes a short drive to a trailhead & charge from the van alternator while driving will get me halfway to 100%
New system +180W solar, so now 390W solar. Kept the old battery until its dead. Added a 200 ah AGM. Added 2 e-bikes, with 505 wh batteries each. A typical ride will take them down to 20-40% SOC.
kite_rider 11-03-2019 05:11 PM
Promaster with optional 220A alternator. Home built 180Ah LifePo4 battery in parallel with a fresh 105Ah AGM. Lithium Charge algorithm controlled by a Thornwave Powermon Bluetooth controller that connects and disconnects the Lithium battery via a simple automotive relay to keep it in the 20% to 85% charge range. AGM camper battery is always connected to the alternator and is separated from the coach battery with a Shure Power battery separator.
Solar: 0%
Alternator: 100% (usually disconnects Lithium battery after around 30 to 45 minutes of driving)
Shore power: 0%
I've travelled the month of Oct on a typical trip from Oregon to Texas. I'm usually going somewhere every day, but there were a couple of times when the van sat idle for 2-3 days. I never needed to idle the engine to charge the battery. Normal driving worked fine for re-charge. Biggest load is the microwave oven, but it's only used up to 10 minutes max on a typical evening and morning meal time. Heater on 24/7 in cold climates and Norcold electric fridge on non-stop.
I've got a 200W solar system that I can't decide if it's even worth putting back on. Note, I travel with lots of toys and use roof rack space to haul them while camping in the van.
hbn7hj 11-03-2019 09:08 PM
Class C
200 AH lithium 225AH FLA 200 watts solar
150AH per day. 2/3 from generator 1/3 solar
Class B
100AH lithium 100AH FLA 100 watts solar
Designed to use the generator but with a DC to DC 40 amp charger the alternator takes care of all of it.
80 AH per day with a compressor cooler .
MsNomer 11-03-2019 11:54 PM
DIY Promaster campervan
200Ah Trojan AGM
15A Shore power charger (anemic—bought when I only had one battery)
300W Solar
180A Alternator with SurePower Separator
700W Microwave that draws 1100W
Instant Pot
Induction cooktop
750W Sous Vide for hot shower water
800W Water boiler
George Foreman
Webasto
Laptop
We consider all three charging methods essential:
Shore power is necessary when parked in our shaded driveway. It also allows us to camp for days in the rain, which I enjoy. When the sun shines, solar is almost always sufficient, but if we’re moving, we let the alternator do the heavy lifting.
Our loads increased considerably after we bought our batteries. We really would be better with 3-400Ah. I’m also monitoring lithium prices.
bigfelipe 11-04-2019 01:32 AM
2007 Roadtrek SS Agile as it was built plus a 200w solar setup. 220ah of wet cells, Onan propane genny.
I rarely plug in unless I am staying in a friend's drive or topping off before a trip. I run the genny in small spurts to run the ac/microwave/coffee maker. The solar keeps the batteries topped more or less while sitting and helps with minor usage on trips...
booster 11-04-2019 01:38 AM
Just a reminder that how much each charge source is used, and how much power you typically use in a day would be very useful to know. :D
bigfelipe 11-04-2019 01:49 AM
I never calculated how much power I use.
Boxster1971 11-04-2019 02:15 AM
My Airstream Interstate has the noisy Onan generator that I rarely use. It has more hours on it from routine exercising than for actual use.
I have four 100W solar panels, 400 watts total, charging my 440AH AGM battery pack. Same pack as booster with four 6V Lifeline AGMs.
Most of my charging is from solar on a total hours basis as the sun keeps all batteries fully charged when parked in my driveway. The van is my second vehicle so it sits in the driveway when I'm not on a road trip. I travel in the van about 12 weeks per year for about 20,000 each year. When I'm home I drive it at least once a week.
When traveling the sun and engine alternator keep batteries charged as I tend to boondock when just driving from point to point.
When arriving at a designation like a friends house solar keeps the Nova Kool refrigerator running and batteries charged.
When at a campground I will plug into 120VAC external power as it is available. If I need air conditioning overnight I'll seek 120VAC external power. Generator is too noisy to run while trying to sleep. Heck the A/C is noisy enogh that I need ear plugs to sleep when it is running.
InterBlog 11-04-2019 11:06 AM
TL;DR - for cross-continent trips in which I remain off-grid for up to 5 weeks at a stretch:
- 4-way charging (shore, propane generator, solar, and alternator)
- 90% solar recharge
- 5% alternator recharge
- 5% propane generator recharge (largely because of it being exercised periodically)
Elaboration - DIY system with:
- 300 watts solar (the original high-efficiency panels that had been sold by Grape Solar but are perhaps no longer available)
- 2,000 watt inverter
- 300 AH lithium battery
- Vitrifrigo marine fridge (Danfoss compressor)
- A heavy load of electronics because I run my professional office part time out of the van, so I might be running cell booster and inverter, two 12 V cell receivers (AT&T and Verizon) a large workstation (larger than a laptop) plus multiple display screens and an iPad 12.9-inch Gen 3 up to 12 hours a day at times. Just as a point of reference, Cherie Ve Ard once declared that I was "eating the sun" (in other words, using a lot of power).
No doubt some readers will look at that assemblage ^^ and think “What the freak!” on my non-intuitive charging distribution. Let me explain.
- The propane generator was already on the van when we bought it second hand. We thought about taking it off, but “if it ain’t broke, don’t fix it.”
- We started out with just one AGM battery, and originally added solar for that, because the OEM alternator charger was useless.
- But then about a year later, we got bit by the lithium bug and installed all of that stuff.
- As part of the lithium job, we upgraded the alternator but quickly learned the hard way not to rely exclusively on it as a charging source after burning out the alternator clutch pulley 17 months into its life (Bosch 200 A). Even with precautions such as the Sterling which is specifically designed to prevent alternator damage, we still use the alternator charging option sparingly and electively. A properly-sized and managed alternator is NOT going to be trouble-free because of this weakness that has been engineered into it (the clutch pulley).
Theory meets real life when you learn just how valuable it is to have charging OPTIONS on the road. I love having redundant solar because I’m almost always in a “set it and forget it” frame of mind. But there have been specific circumstances when I’ve had to switch to all of the other three charging methods in turn.
booster 11-04-2019 11:28 AM
Did you happen to check to see if other brands, duty rating, clutch pulleys were available for your alternator. There appear to be a lot of different brands and costs out there, up to a very expensive one the I think davydd had a video of some time ago from ARV. I assume yours was the kind of one way mechanical clutch style that are used to take out belt flutter and not a true on/off clutch? A lot of folks think that we are referring to a air conditioner type clutch from the confusing terminology the industry uses. Adam at Nations may also have some input on the issue as they are big supporters of using clutches on all of the high output alternators.
Perhaps it would be of benefit to be truly redundant and add the second standalone alternator so if it does have a failure you can still run the van off the original, and if the original fails you can run the van off the add on.
InterBlog 11-04-2019 01:09 PM
Good questions. I don't know. We took our first Bosch 200 A alternator to a local repair shop, and they fixed it, so now we now have a repaired spare $500 alternator sitting on our garage shelf - lucky us (the first one died while I was 1,500 miles from home, so I had no choice but to replace with new, tote the fried one back home, and figure the rest out later).
The local shop to which we took it told us that it used to be possible to defeat the weak clutch pulleys and install a workaround to make them more robust. But Bosch got wise to that practice, and proceeded to re-engineer their alternators so that this could no longer be done.
I don't know the full story here, but it seems bat-poop crazy to me that Bosch would not only PRODUCE a fragile alternator to start with, but then they'd intentionally prevent the end user from hardening it.
We have not run down the true backstory and causes of this situation, because of competing priorities. One day, maybe I'll find the time to give it the analysis that it deserves. The problem is reportedly not specific to Bosch, nor is it specific to alternator charging such as we are doing. Here's a useful 3-minute YouTube made by an independent alternator specialist that talks about it further (except this is a 2013 video and reportedly, the workaround he shows can no longer be accomplished).
https://www.youtube.com/watch?v=QUs4Y5ZMiTU
Davydd 11-04-2019 01:10 PM
The video by ARV has been posted here many times by others. For second alternators it is relevant to this thread. I probably was one of the few that had installed the Nations alternator and upgraded the Delco alternator in the same van. As you can see the Delco is considerably bigger but still fits in a Sprinter safely and securely off the pavement and behind the bumper. I don't know if that is the case with a Promaster. ARV also has the 48v Volta alternator (considerably smaller) and system, I think, that Winnebago offers in Promasters. I don't know if ARV offers the Nations alternator anymore.
https://www.youtube.com/watch?v=XANYxoEF_HY
@Michael 11-04-2019 02:18 PM
Two scenarios:
First -
My old travel trailer had a propane fridge, LED lights, two 6V golf cart lead acids and a 65W solar panel. My load was low enough that the 65w panel could keep the fridge and lights going indefinitely even in part shade. I didn't have a battery monitor, but suspect my load was 10-20AH per day, all of which was replenished by the solar.
Now -
I have a compressor fridge, two 100W panels, alternator that as configured can charge up to about 40A, a 55A WFCO converter, Onan generator, two 100AH lead acid and a 100AH battleborn behind a 40A B2B.
Load is 50-70AH per day, almost all from the fridge.
The solar keeps the fridge going during the day, but doesn't add much net charge to the batteries. If I'm not driving I have to run either the engine or generator for at least an hour.
Estimate that less than 50% of my load is replenished by the 200W solar.
After running the Onan for an hour, I decided that the engine is a vastly better at power generation than the Onan. From what I can figure, the existing heavy duty alternator on the Transit can charge at least 80A without issues, so that'll be what I focus on next.
