-   Practice your forum skills here (https://www.classbforum.com/forums/f21/)
-   -   Lithium Test JWB1 (https://www.classbforum.com/forums/f21/lithium-test-jwb1-9902.html)
JWBrown 11-12-2019 11:58 PM
Lithium Test JWB1
This is a test of (my first) new install thread and uploading of pics. FEEL FREE TO IGNORE.
https://www.classbforum.com/forums/m...icture1218.jpg
And the side view:
https://www.classbforum.com/forums/m...icture1227.jpg
Thank you.
booster 11-13-2019 12:11 AM
It looks like the AGM and lithium batteries are tied together at the solar controller. I think that would give you a mismatch of voltages when off charge that might not be desirable as the lithium will be constantly charging the AGM. Does the solar have dual battery isolated outputs?
JWBrown 11-13-2019 12:23 AM
Wow, that was quick. I have read with interest all of your posts and help to others on this board (thank you for that), so I am anxious to hear your thoughts when I post the entire thread later tonight. This is only the very first test of the post I plan to make with a lot more detail, as I wanted to ensure I knew how the forum software worked. The two outputs are indeed isolated from each other for exactly that purpose. When I post the real thread, you will see there is a lot more to the system than these two random pieces convey. Thanks again.
Copyright ©2000 - 2022, vBulletin Solutions, Inc.
