youngnretired
Last night while turning into a boondocking spot, we bottomed out on a root and broke the piping from the bottom of the Roadtrek's exterior tank. It looks like just the "T" fitting is broken, and I'm 95% sure the tank is OK. The "T" fitting also had the drain valve on it to drain the whole system.
We'll need to winterize the van likely in the next week possibly by Dallas before heading north for home.
Does anyone know how the piping from the bottom of the tank runs to the rest of the vehicle and will i have to get this fixed in order to properly pump antifreeze thru the piping and winterize the piping from this tank? Or since the line going to the chassis and it's disconnected, will that essentially drain itself of water as I drive? The interior tank and everything else is fine and I can winterize the system thru that tank. Just don't know about the lines specifically from the exterior tank.
Thanks
Thanks
