sergiorialta
1995 VW Riata new to me
228000 miles on the Odo. 2.5L % cyl engine Auto 4 speeds transmission.
Bought it at an auction, and on the way home the ranny gave up, towed home.
Then realized there was a big leak at the main (input) seal. Dropped the tranny, (big undertaken) changed all seals, and installed a new external cooler to it.
Now after fixing a bunch of small things while putting the transmission back in I have been running into shifting issues. I am at a loss with this last one tho.
All the work is done except for this issue that prevents me from starting or test-driving the unit. The shifter in the cabin pulls all the gear from P to 1 but won't go back towards the P position, once in 1st it stays there until I go to the transmission by hand and shift back. Not super sure is reaching Park either, I'll double-check tomorrow. with the cable disengaged.
The clip in the mid bracket that holds the cable is there fine, I pulled the bracket off; seated it right, and reinstalled it. Then from this bracket, there is the cable and a soft spring coiled around it, it just does not make sense that this spring only would push back the transmission shifting lever, I think I might have misplaced another spring somewhere.
In anycase any advice would be greatly appreciated.
Thank you very much.
