Thanks for your reply! Yeah, that's the same thick grey OEM manual that I have. Anyway, I got it done. Mostly a very easy job, though not especially pleasant. I was surprised at how small the auxiliary transmission oil cooler is -- it doesn't get in the way at all. I was also surprised at how little transmission fluid came out when I disconnected the line (which I did by unscrewing the fitting, by the way, rather than pulling out the quick disconnect -- I have the disconnect tool and the radiator came with new fittings, but I see a number of youtube videos that just unscrewed the fittings and had no problem with leaking o-rings, so I figured to try that first).
I considered taking the opportunity to flush out the radiator fluid and put in something better than the universal fluid that I've been using in the van for ten years. But, in the end, quick and easy was preferable. Maybe I'll flush it out and change it later.
