[IMG alt="InterBlog"]https://www.airforums.com/data/avatars/m/478/478512.jpg?1759257483[/IMG]
RV LIFE Pro
Joined Oct 11, 2014 Posts 7,434 Location
League City, TX AIR Member # 92576
How did you deal with leak when it started? LPG Is highly explosive when vaporized. Hope the tank wasn’t full.
Not sure which poster this question is intended for.
In my case, my tank was near full but my leak was a pinhole. I caught it early, in other words, because I happened to be rummaging around under my chassis for some reason unrelated to propane, at which point I heard a noise and saw bubbling.
There’s no substitute for getting on one’s back on a creeper and seeing what’s actually going on.
OP
Joined Jun 25, 2018 Posts 170 Location
IL AIR Member # 137677
In my case, the tank was also full.. leak started as a pinhole but expanded as I scraped the rust off. It was coming out pretty good so I called the Fire Dept. At their advice we just let it depressurize naturally and kept ignition sources away.
It was still out gassing after 48 hours but reading empty so we disconnected the regulator and bled the remaining gas (much more than I expected) through the solenoid valve
