2001 Roadtrek Popular 200
garysroadtrek
Jul 28, 2019
4
MN
2001 Roadtrek Popular. Only 76,800 miles. Very clean. Chevy Express 3500 chassis. VIN: 1GBHG31R011142569 5.7 L/350 CID SFI gas V8 engine. Has a trailer hitch. 321.6 hours on generator. Nonsmoker. No pets.
Mileage averages around 13.5MPG for me at freeway (70MPH+). It's been as low as a bit over 11 for 100% (almost) in town driving, and as high as almost 17 in highway driving where I was stuck at a fairly steady 45 MPH due to road construction. At 55 MPH, it's something around 15 MPG.
I bought this in the fall of 2018. I'd be keeping it if I hadn't bought a new car. Everything works and I've replaced or fixed a number of things.
New wipers 4/21
New CO monitor 10/20
New airfilter 9/20 at aproximately 73,085 miles
Replaced driver’s door regulator motor 9/3/20
Oil and filter 9/1/20 73,055 miles.
Replaced rear driver's side window operator 7/20
New AC July 2020.
New tailpipe 8/29/20
New sewer hose 9/20 (replaced with a much heavier / thicker one)
Replace top vent 6/20
Replaced water pump 5/20
Generator - spend $1826.72 to replace the carb and fuel pump. Runs great now.
New starter 5/19
Aligned and replaced idle arms 5/19
Installed a backup / rear camera
Installed an alarm / remote entry
I have repair records, and the person before me passed his on as well. Below are a few of those dates / mileages:
Radiator flush 8/4/16 58,184
Transmission flush 8/4/16 58,184
Brake flush 11/21/06 48,110
Rad flush 11/21/06 48,110
Trans flush 11/21/06 48,110
Shocks 11/21/06 48,1110
Some specs from the spec sheet (more info is, of course, available online):
2001 EXTERIOR DIMENSIONS
Length 6250 mm/20' 6"
Height - overall 2590 mm/8' 6"
Width - overall (w/o mirrors) 2210 mm/7' 3"
Wheel base 3530 mm/139"
Unloaded vehicle weight * (no opt.) 3450 Kg/7500 lbs. (approx.)
Gross vehicle weight rating 4309 Kg/9500 lbs.
* Includes weight of base vehicle and fuel only. Does not include weight of optional equipment, water, LP gas, cargo and/or passengers.
2001 INTERIOR DIMENSIONS
Standing height 1900 mm/75"
Single bed length - front 1650 mm/65" left, 1750 mm/69" right
Single bed width - front 660 mm/26" (maximum)
King bed length 1930 mm/76"
King bed width 1950 mm/77" (maximum)
Twin bed length - rear 1930 mm/76"
Twin bed width - rear 690 mm/27"
Water tank - fresh 125L/33 US gal.
Water tank - grey 105L/28 US gal.
Water tank - black 40L/10 US gal.
2001 STANDARD MOTORHOME FEATURES
Air conditioner 110V built-in, 10000 BTU
Aisle 30" wide/760 mm (wider above counter)
Battery - auxiliary deep cycle, 68 amp.
Battery storage below floor at rear
Beds - dual density foam 130 to 180 mm/5 to 7"
Carpet 28 oz. 100% Dupont nylon
Connections LPG for BBQ with quick disconnect
Counter top laminate
Detectors smoke, LP gas & CO
Faucet - galley dual control
Floor - lowered 1755 mm x 810 mm x 80 mm/69" x 32" x 3"
Furnace - 'Suburban' LP gas automatic, 16000 BTU
Generator ready package for 'Onan'
Lights - 12V florescent & incandescent
Microwave oven - 110V w/turntable, 20 L/0.7 cu. ft.
Monitor panel water levels, battery charge & battery disconnect
Power converter with charger 110/12V 45 amp.
Privacy area with bi-fold doors, patented
Range hood - 12V with exhaust fan & light
Refrigerator - 'Dometic 12V/110V/LP gas, 4.0 cu.ft.
Refrigerator venting patented integrated
Roof vent - 'FanTastic - 12V low profile power w/thermostat
Sewage hose system patented 'Dura-Drain' system
Shower stand-up in aisle
Storage area across the rear
Storage compartment running boards & rear quarters
Storage capacity - standard 90 cu.ft. in 200, 114 w/options
Stove - two burner LP gas
Table - dining - cloverleaf 20 x 20 closed
Tank - LP gas 46 L/12 US gal./52 lbs.
Toilet - 'Thetford' marine with foot pedal flush
TV Antenna built-in
TV cable connection external
Cabinet with pivoting shelf
Water fill - fresh �” location step well to reduce clutter & prevent tampering w/supply
Water heater - 'Suburban' LP gas with bypass, 23L/6 US gal., 12000 BTU
Water system - on demand 12V with 'Shurflo' water pump
Water tank capacities (see Interior Dimensions)
Windows frameless awning type
Windows - roof 3 with curtains
