Greetings. First post. Please be kind!
I recently purchased the indicated Class B. I also own a Class A and the difficulty in accessing and servicing components on the B is proving to be a bit of a surprise. I get that the size requires maximizing use of the available space, but dadgum!
To the point, I understand the transfer switch is located along the passenger side, in the box underneath the sofa/bed. After a great deal of swearing and contortion, I was finally able to get into the side of the box from under the sofa/bed and observe the Tripp Lite Inverter. However, to access anything else in this box, it appears the top of said box must be removed. I was able to remove 5 of the 6 screws, but one appears to only be accessible by removing the sofa/bed entirely. I don't mind carefully cutting that last screw to avoid this, but don't want to do it, if that doesn't allow me access to the actual transfer switch, which I suspect may be the reason I'm not getting any power from the generator, which starts and runs well. Per the previous owner, everything worked fine before I picked it up... (Just don't bother commenting on this please. It won't serve any useful purpose...)
