phantomjock
Greetings –
First “real” posting about our van. It is a 2008 Roadtrek 170 Popular, on a 2008 Chevy chassis. Both were coincidentally produced in Canada. Having come from a sailing/cruising life, small spaces and preparing to live “off-grid” are not new. I am an engineer, inveterate tinkerer, and often willing to; “not leave well enough alone.”
The van (yet un-named) has few, if any, upgrades from the original. There is a black tank dump port on the passenger’s side which we understand was a mod, and some new carpet and cushions. The starting battery is brand new, the previous one having failed on our second night aboard during our delivery trip from the NE to our home in the Florida panhandle.
When the starting battery failed, I was disappointed that we couldn’t just turn a switch (1-2-Both) to get going. The small capacity of the House Bank was also surprising. A third item of surprise, the only on/off for the propane was just a manual valve on the tank. For over 30 years of cruising and living aboard, we had become accustomed to using a 12V solenoid routinely and the on-deck shut-off only for longer term. We were pleased with the convenience of that configuration. It should be easily adaptable to this van. These mods will be definite upgrades in the program, and early on.
With a draft “to do list,” I mapped out a set of improvements and additions. Rather than tackle them all at once, or in a haphazard fashion, I set them out in a “phased” approach. The picture might help explain, save me a bit of typing, and you a bit of reading.
For image clarity, obvious connections are not shown; alternator wiring, all 110 socket locations, 12V lights, planned additional 12V “accessory” sockets fore and aft in the cabin, etc. I’ll outline each of the PHASES as we tackle them and, and hopefully be able to document the progress in this thread – once it warms a bit outside. [Temps in the 40s make for slow work in the driveway]. So, here goes the first step of the plan.
PHASE – 1: Install a Blue Sea ML-ACR #7622. This automatic charging relay should provide us the peace of mind (and opportunity for control) to isolate and combine the starting and house battery banks. We believe we can then also join for charging, and when necessary, give a little boost. Not to concerned about the technology, seems well established and although the installation will require some engine bay “disassembly” nothing to dramatic. Simultaneously, I’ll pop-in a cheap battery monitor, just to see how the house battery is doing; volts, amps, Ah in/out, etc. It comes with a shunt and hopefully performs as advertised. The Blue Sea charging relay is inbound and should arrive in a few days.
But we expect the outside air temps will drop to the ‘teens for a week, so don’t expect an update here too soon! I’ll take some snaps, but don’t expect a YouTube Video either.
I look forward to everyone's encouragement. I've read what seems like over 1000+ pages of the forum. There are some very well though out (and documented) upgrades I'll be "praising" by replication!
Cheers - Jim
Cheers - Jim
