2008 Chevy Express 3500 Intermittent Charging Warning
Original Member Title: Chevy charging anomaly
A member’s 2008 Chevy Express 3500-based Roadtrek displayed a charging warning and battery light after a lunch stop, with the ScanGauge reading 12.2V before returning to about 14V after 15 minutes and the warnings clearing. The vehicle had approximately 100,000 miles, its original alternator, and what the member identified as a finned, rectangular battery isolator rather than a charge relay/separator.
Members suggested checking and cleaning battery connections, alternator connections, and...
GroupB
Jul 1, 2015
143
MD
4 hours into a trip stopped for lunch. A short time later started vehicle to continue. A mile later “charge not working” and battery light on. 12.2V on SCANGAGE volt meter. After 15 minutes went up to about 14V. Message went off; shortly after light went out. Continued to our campsite. Have not tried it since. Will be leaving Thursday for home.
2008 Chevy express 3500. 6.0 L 100,000 miles, original alternator and isolator. Disconnected chassis battery when we stopped and it’s sitting at 12.9 V now.
Any similar experience or suggestions?
Are you sure it has an isolator which is a diode based unit and not an automatic charge relay/separator. Which it is can make a difference on some models. My guess is that it is the separator type as that should be stock on a 2008 Roadtrek.
Take a look at the firewall just off center to the driver side under the hood and look for a round cylindrical item with a squarish box on it and two heavy cables attached, plus some smaller wires.
With a separator, it would mostly eliminate it as an issue for the Scangauge to see.
It sounds like you may have a loose cable at the battery, alternator or block. Carefully remove and clean all of the contacting areas and make sure the go back together tightly. Hopefully, that will fix it as the next step would be connections from the PCM to alternator as long as it is a 2008 chassis which is the first year for the PCM controlled alternators in the vans.
In addition to the advice above, suggest to clean ground points as well. Corroded grounds can cause all sorts of strange issues.
After purchase of our 2010 210P, I went over all pos and neg connections - all grounds, circuit breakers etc. Including the circuit breaker run under the van above the genset. Lots of dirt. I've also replaced the original battery isolator with a Blue Sea auto battery relay. Its a magnetic latching unlike the original heat creating relay that needs constant power to stay latched.
Good suggestions. I was condemning the alternator but couldn’t see how a failure would reverse itself. A bad connection makes sense.
It has an isolator. Red rectangular box with cooling fins. 08 Roadtrek on an 08 chassis. My understanding is RT would use leftover parts on the next model year if it was invisible to the customer. I’ve come across this on several cars over the years.
The LS series drivetrain are a bit notorious about grounds. We've got a 2010 Silverado that I added more robust grounding than the factory and I've done the same with our RT. Theres actually kits available but I used my own cables, etc.
After arriving at the park and turning the engine off, I disconnected the negative battery terminal to prevent any discharge when opening the vehicle doors. Was not loose or corroded. Reconnected to drive home.
Made it home without incident. Everything working as it should. Will be examining the grounds, etc.
I have seen this same type thing on my 1996 Buick Roadmaster with a side post battery. On it, there appears to be something not right with cable end for the positive connection even if it carefully seated. I think someplace before I got the car, it must have been badly crossthreaded or something, messing up the cable. It will randomly not start, but wiggle the cable or take it off and put it back on and it starts. Removing and installing the negative doesn't correct it, only the positive so not a computer reset issue. Side post batteries can be a PITA.
I switched our 07 Roadtrek to a top post battery at the first battery change.
Moved the RT 4 times during winterization process, running the engine for about 10 minutes each time. Vehicle charging the first three times. Not charging the last. I plan on replacing the alternator but it won't be any time soon.
I would clean and tighten the relay terminals mounted on the isolator before replacing the alternator. I have seen this problem reported many time in the Roadtrek Chevy Owners group and I had this problem on my 2004C190P. In my case the terminal spade connector did not fit snug on pin 87.
The relays they use on the isolators also are known to fail. Best to check to see if the alternator initiation is signal is making it through the relay to the alternator. If it is a 2008 chassis for the Chevy that signal would come from the PCM of the van. A 2007 chassis would have a standalone with a field % signal back to PCM but no initiate from the PCM.
Personally, I would just change out the isolator to a relay based separator/charge controller so the alternator controls go back to all the OEM Chevy setup with no extra relays or interference from the isolator type setup.
The above comments and schematic clued me in to the Bosch style relay that was hidden under a gaggle of wires next to the isolator. My guess is - that it is the cause of the intermittent no-charge condition. I had bought a Blue Sea charging relay - 7610 - to have on hand if the isolator would fail. Time to put it in.
I totally
agree with that idea.
