youngnretired
Yes, it still has the original Tripplite in it. At the present time, I don't plan to run nearly anything on the inverter when not connected to shore power. Just 4 years ago we moved up from tent camping to a popup camper without a working water tank in it, so some of these conveniences in the van we're just not used to. Maybe I'll upgrade the inverter system in a couple years or so when Li-Ion batteries become more mainstream or I'm forced to change it out due to non-functioning. Just trying to take care of minimum items at this time as it's been pretty $$$ to get into one of these and do what I've needed to do so far. I still want to install a gauge to monitor transmission temps and likely install a trans cooler and a few other items. I do know that when plugged in to shore power, I have 120V at the receptacles. I've also got to service the generator. I believe the fuel pump is shot as I had it running twice, once for 15 minutes and the next for 3 before it quit each time. Fuel line was dry after each time running. I'm currently working on an adaptor for my jack to hold the generator so I can drop it to get inside and investigate/change out the pump. I don't know if the generator is going to give me 120V or 100V, but I suspect 120V as it should be just like connecting to shore power as it's a separate power source.
Also, to close out a couple items:
The refrigerator exterior fans are likely powered by the DC circuit for the fridge. I pulled the DC #9 fuse and the fans kept running. Still haven't pulled the cover off yet to see how they're controlled.
I also read the inside cover for the electrical panel to see that DC #9 serves the antenna booster, which I didn't know existed in these. I had previously just looked at the Roadtrek manual that said media cabinet. I confirmed that DC#9 is behind the booster cover when I removed that yesterday morning. So I can research further for AC or DC Tv's and equipment, and now test to see what 120V equipment may run on the inverter.
