youngnretired
Our macerator pump blew a fuse upon return home from a trip. Here's what I did upon discovering this:
I replaced the fuse, hit the button and no pump action, blew another fuse.
I then replaced the fuse and turned the 12v on. Fuse was OK. That tells me the issue is on the load side of the switch.
I then cut the 12v wire right at the pump and rigged up a fuse protected test line and proceeded to hotwire directly to the battery to bypass all wiring. Lots of sparking when I touched the line to the battery and i didn't hold it on the positive terminal for long, but no pump rotation and the fuse didn't blow.
I then measure resistance at the pump. Its about 7 mega ohms.
I then tried holding the pump button while the pump was unwired. Fuse didn't blow so there's not a grounded connection in the wiring from the panel to the pump. My testing shows that the wiring is good and the pump is bad.
Anyone have any idea what the resistance of a new pump motor should be for comparison? 7 mega ohms seems pretty high to me.
