GpnAZ-ClassB
We recently purchased a 2011' Airstream Avenue which is built on a Chevrolet 3500 Express van. I plan to use it for my photography trips and quick weekend camping trips with my wife. I was worried about it's lack of clearance and I like getting off on the back roads so I thought a lift was in order. After hours of reading different threads on lifting the Chevy van I decided to go with WeldTec Designs 3" lift spindles, coil spring spacers and Fox shocks. I had the spring shop build new progressive rate spring packs although we still had to use 2" blocks because of interference with the front part of the spring pack where the waste tank wrapped around it. They also installed a forward facing rear stabilizer bar and of course longer brake lines. I had Cooper Discoverer AT3 285/75R-16 tires put on the 16"x7" Alcoa wheels that came on the Airstream. I also had the 4wd shop install 4:10 gears with an ARB air locker with twin compressor with air up kit for airing up tires. During the test drive the Brake/ABS light sensor came on so we decided to order a Bully Dog tuner to dial in the new tire size along with the new rear gear ratio, hopefully that will take care of the brake/ABS light and correct the speedometer. I was very pleased with the way it drove and handled, it actually drives better then stock, IMO! Over all I ended up with 5.5"-6" of added height. I am happy with the added clearance it gave me and I can't wait to try it out on the back roads to see how it drives and handles. I actually wanted a van with 4wd or AWD but decided to drive this for 6-9 months to see if I would really need it, with all the stuff hanging underneath I would need to be careful what type of terrain to drive it on anyways, even with 4wd. Thanks to all that provide info on this forum, it really helps in the decision making!
Stock height
Lifted height
Stock height
Lifted height
Lifted height
Stock height
Lifted height
Stock height
Lifted height
Lifted height
