Jan 14, 2025 #1 PG Pgooch46 New Member Joined Jan 14, 2025 Messages 1 Location Mi Electric above stove light and plug don't work. all other lights and outlets work brakes and fuses good. Any ideas thanks phil
Jan 15, 2025 #2 RO roadversatile21 New Member Joined Jun 12, 2016 Messages 2 Location CA Could it be that the inverter has to be on?
Jan 15, 2025 #3 booster Senior Member Joined Aug 8, 2010 Messages 12,537 Location Minnesota Pgooch46 said: Electric above stove light and plug don't work. all other lights and outlets work brakes and fuses good. Any ideas thanks phil Click to expand... If you are talking about the AC power and you are plugged in to shore power, take a look for a GFCI outlet that is tripped. On our 07 190 it was the outlet that is on the step behind the side door entrance and was behind the rearmost door.
Jan 19, 2025 #4 CH ChicagoTom Senior Member Joined Mar 31, 2018 Messages 374 Location Tinley Park IL GFCI and the power needs to be on in order to reset it. You need to be plugged in.
