Lorie-ClassB
Hi, I have the 2015 Roadtrek SS Agile -- 4 AGM batteries for the coach with 2 batteries under the hood and 2 batteries that are mounted under the rear of the vehicle where the spare tire would normally be mounted. All these batteries are dead and need replacement. I also have the underhood generator and 3 100 watt solar panels.
The rear battery tray release (pins that need to be removed) are frozen and we cannot get this battery tray to release even after using penetrating oil, placing a floor jack under the tray and relieving the pressure, and trying to tap out the pins. The previous owner had the vehicle in at the RV garage and they couldn't even get this battery tray opened.
If we just replace the 2 front AGM batteries for the coach, can we just disconnect the rear AGM batteries for the coach and just live off 2 front coach batteries? I use a minimal amount of electricity.
I would appreciate any advice.
