bpestun
Our refrigerator in our 2017 Travato Model 59G lights on gas but won't stay lit once we are underway ? Anyone else have this problem ? My refrigerator is a Dometic Model RML 8330 Gas,12v, and 120v AC model.
It is certainly true that it is unsafe and often illegal to run propane appliances at gas stations, propane fueling stations, and some tunnels.It is true that driving with propane flame lit is considered dangerous and out right illegal is some situations. I think some states may have laws against it while under way. I know that some areas forbid it while traveling in tunnels or on ferries.
And even require RVs to shut off propane supply altogether either closing the hand valve or shutting off via a safety solenoid switch.
Most gas stations have signs something to the effect “No Open Flames Within 50 Feet of Pumps” or some form of that.
And if you think about it the Travato G and many other RVs have the refrigerator on same side as the gas cap. So yea it’s risky fueling your RV while your propane refrigerator is lit.
My Winne Era has the same refrigerator. The flame on mine also blows out while driving.
I just leave it on 120 AC and let it run through the inverter while driving. Before I had the inverter I left it on 12 vdc while driving.
Does the fridge work better on the 120v inverter than on 12v?
I would caution you on being a realist on this forum. It can be almost as hazardous
HOUMA — An Indiana couple’s RV caught fire at a Barrow Street gas station Wednesday, burning for about a half hour as spilled fuel and a propane tank on the vehicle fed the flames.
Irwin Binder and his wife, Linda, escaped unharmed with their Yorkshire terrier, Holly. Binder, 73, said the blaze started as he prepared to fill up the Roadtrek recreational vehicle and the nozzle spewed gasoline, igniting when it came into contact with a pilot light on the RV.
See: https://www.houmatoday.com/news/20100325/gas-station-fire-destroys-indiana-couples-rv
STRONGLY SUGGEST you turn off fridge pilot lights at gas stations, even if you have a diesel vehicle, because someone else's close by gas vehicle gasoline fumes could ignite from your pilot light. Especially in hot weather. Saw a diesel owner saying he did not turn off pilot as he has diesel.
I did and on the first page of results there was exactly one fire at the pump, the incident you posted. It doesn't happen quite frequently. That's not to say it's not a good idea to shut off the flame when tanking up, but 1 event in 8-9 years is not "frequently".Plenty of more recent ones - just google "RV Fire at gas station" it happens quite frequently unfortunately.
