blackbourn3704
- Joined
- Aug 1, 2018
- Posts
- 94
Does the engine battery get charged from shore power? Mine does not (not now anyway)
Usually not. The isolator separates the chassis battery from house battery. House battery is charged from the converter designed for them. You can design a system where the chassis battery can be charged from shore power. I believe such devices/ systems can be purchased over the counter?
If you want to charge in both directions and still separate when not charging, you just need to replace the diode isolator with a relay style automatic charge relay/separator. Lots of folks have done that upgrade.
I have a Sure Power 1314-200 Uni Directional Battery Separator- 12 volt. What relay style automatic charge relay/separator would work best? Chassis battery is AGM and house battery is lithium.
Thanks
With mixed batteries like that, I don't really know if you should do bi-directional relay or not because of the voltage of the lithium battery will hold the separator closed and drain the lithium charging the starting battery, possibly at very high amperage.
Most with a mixed system like that would have a B to B charger in the circuit to isolate the lithium and some of the B to B chargers do have an out put to charge the starting battery, I think.
Just tying them together without the diodes probably wouldn't be a good choice unless you add a B to B and then you lose the bi-directionality anyway. AFAIK, you could just remove the isolator if you put in a B to B charger.
Thanks for the information. I have a solar controller and dedicated 100watt panel to trickle charge the chassis battery. I was looking a way to reduce to a single charging source?
Single source for the lithium coach battery? If so, unless you plug in every day, the engine charging is about the only way to single source it.
The engine is not going to give good lithium control of charging though, so much better to put in the B to B and if you are OK with only engine charging, shut off the shore charger completely and make sure the solar isn't connected to the coach batteries.
If it is a bit lithium bank, maybe over 300ah or so, you probably would be best off to install a second dedicated alternator for the shore charging, or upsize the factory one a bunch and use a big B to B charger.
Not normally a problem, but the wife had been sick for a few months and I thought shore power was charging both coach & engine batteries. There is a tiny cabinet under the 3rd seat accessible when the door beside it is open. It has an ac outlet too. Just right size for a small trickle charger and run a wire up to the engine battery. Just leave it plugged in, presto simple shore power charger.Usually not. The isolator separates the chassis battery from house battery. House battery is charged from the converter designed for them. You can design a system where the chassis battery can be charged from shore power. I believe such devices/ systems can be purchased over the counter?
I use the engine and solar for the chassis battery. The house battery is charged primarily by generator and solar. Occasionally shore power. Very seldom is the engine alternator involved with the house battery. I have a cut off switch which disconnects both systems. If the house battery is very low, I will run the generator while driving. It does a great job charging the house lithium.
Do you have a selector switch on the solar output so it can't be connected to the starting and coach battery at the same time, or maybe two isolated outputs from the solar charger? You will be constantly running current to the starter from the coach batteries if they are connected without some blocking diodes or such.
How much coach battery capacity to you have? Shore chargers off the generator normally have relatively low output.
