Mountainsarebest
2013 Airstream Interstate.
Any suggestions.
Any suggestions.
Generator runs always. The circulation fan starts a few seconds after the thermostat is turned on like normal. It runs several seconds, then I hear the compressor kick in based on the generator draw. It runs maybe another minute or two, then the fan turns off. After a couple minutes it kicks back on (and I think the compressor kicks in too), and it will run this cycle for 10 or 15 minutes until I shut it off. This generator is the original factory unit with 3.5 hours, so I would think the generator is working fine?Can you explain a little on what happens? There's the circulation fan that starts first, then the compressor kicks in. Does only the circulation fan run and the unit shut down when the compressor is to start? Does the generator surge or stay running smoothly?
