Anyone tried making their own awning?
Nov 23, 2023
11
Colorado
We recently bought a 2000 RoadTrek 190P which has no awning. I don't consider that a serious problem, but it might be nice to have and I'm not interested in drilling and mounting an awning in the 190P's fiberglass top. Having the shade available over the door seems like it would be a plus.
I'm thinking of trying a self-made awning which can be removable, attached along the roof of the RoadTrek using 3M Dual-Lock reclasable fasteners (https://www.3m.com/3M/en_US/dual-lock-reclosable-fasteners-us/)
The Dual-Lock is serious stuff and I've used it to equipment on tables and walls without having any problem. Think of it as the Schwarzenegger version of Velcro; the top stuff takes more than 6 pounds per inch to separate.
For the outer edge of the fabric awning material, I'd work out a support rod and tie-down system. The whole idea would be non-destructive to the van and could be discarded if it failed.
Anyone tried something like this?
Looking around, others might be interested in this somewhat similar awning from Hasika that's about 1/3 the cost.
https://www.amazon.com/Hasika-Water...-Traveling/dp/B00ZKYSCOM?ref_=ast_sto_dp&th=1
Not sure which way I'm going to go yet, as the Moon awning has a very nice attachment system that should be compatible with the fiberglass top on my RT 190P. Also not sure we'd get comparable material in the awning.
I know this isn't the same thing at all, but at a very delicious price ($30 atm) it may be an option some would consider.
https://www.walmart.com/ip/Ozark-Tr...Protection-and-Roll-up-Screen-Walls/895570759
It should provide shade, plus some protection from weather and biting critters. Not being attached to the camper may be a pro or con... depending how/where you camp.
I got mine, but it's still in its box. :blush: So no reviews yet.
Again... different thing, but much cheaper and perhaps similar purpose.
The problem with awnings is that they only allow you to sit next to the van which usually isn't the best place in a campsite. They are also expensive. They also don't address the often most annoying part of sitting outside - bugs.
Here is the alternative that we like the best. We now use one of these instant pop up tents. We have the 10x10 model. It quickly folds up in a few seconds into a flat case that slides behind our rear couch and bed. We use this a lot more than we use our awning. Just a thought.
https://www.amazon.com/gp/product/B07TXBB49X/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
I consider an awning to be an essential part of a RV. I deploy mine primarily to keep the sun from beating down on the side of the van. Even when it’s 80 degrees out at altitude the interior can get quite warm. So if there is no shade available, I park the van’s awning facing south and since the refrigerator is on the opposite side, it doesn’t receive any direct sunlight. It also helps the A/C run more efficiently.
Anyone try to make their own awning
When I brought my Roadtrek it didn’t come with a awning.
I searched YouTube & found a few videos on making a awning for you van/car. I tried it & it was a fail. I then brought the moonshade. Easy to put up.
I’ve tried
A functioning, easily deployable awning is essential. Hell, I want awnings all the way around. Front, back and side to side. Messing around with all of the moving pieces isn’t worth it. I’ve made and used a variety of makeshift awnings. May I suggest looking for a used cassette awning? The last one I bought was a fiamma from Craigslist. Think I paid a $200 for 10x8.
Our first two vans both came with awnings. The number of times we used them could be counted on one hand. When we did try them out, it felt more like a stunt than anything practical. So, we chose not to have one on our current van.
But then, we are more tourers than campers, so...
DIY awning
I had asked a question on FB Roadtrek group & was told not to put a rv awning on because if not put on at the factory it would weaken the fiberglass or something like that. That’s why I went with moonshade.
awning
I've owned my Road Trek SS Agile for 9 years and have used the awning maybe 4-5 times. It's one of the only feature of my RT that I can really do without.
We use our awning infrequently, but since it was the only 1 of 2 ‘must haves’ my wife wanted with our van; we have!
Enjoy the shade or rain protection when we use it. You know what they say, “happy wife = happy life” - so awning is worth every penny.
The other must have was a good bug screen on the slider.
Happy camping :)
Happy camping :)
We didn't use our awning much when we got the van in 2008, but last 4-5 years we find we use it a lot more. Nice for shade when the weather is hot, like it is more often now at the places we go to. Rarely use it in the rain as it aways seems to be very windy also then. We certainly would get another as when you need it, you have it ready to go in a couple minutes.
Where we usually go it is usually too windy to use the free-flying Carefree awning. I think if it had supports it would be a bit better, but as is, basically being a huge sail, it retracts at the lightest breeze.
The few times we used it are split by "most likely helping" to shade the sunny side of the camper, and chasing around the shade which seems to be moving around too quickly. :hide::dance:
we got a kelty shelter tent from rei Affordable easy Offers privacy Can step out under shelter if raining Can be used as a tent Easy t o set up Unless it is windy!!
Moonshade
I have questions to those of you who are using a moonshade. How is it on windy days and how is it attached to the camper. I have never in my life had any luck with suction cups. Is there anything adhesive that would work well, I would rather glue than drill.
that
The kelty tent shelter from rei
is set up on the ground and leans against the van ,the bottom is staked in the ground, and the top has long straps you toss over and tie to someplace on the van or maybe somethin' else close . If it is windy when you set it up it takes a sense of humor but once up is fine We really like it becasue it gives privacy not just an awning ot sit under Moonshade I think needs a roof rack to attach it to and we do not have that as there is the AC and a vent etc on top
We use magnets to hold the Moonshade to our van. The magnets are cushioned in a silicone cup. They can be purchased from Moonfab, or you can very likely come up with your own approach that works just as well.
BUT! :) the roof of our van and likley many others is not metal!
